1. Mendel Leisk
    42,343
    I did think about it, running out of the 5 year component of the drivetrain warranty, but you know: costs me about $30 spring and fall, and keeps me off the streets, lol.
  2. Former Member 68813
    3,524
    983
    US
    i see, but it sounds like a waste of good oil. at those intervals you could switch to dino 5W20 oil or honda 0W20 blend.
  3. Mendel Leisk
    42,343
    Honda 0W20 is $9something per liter, at our local Honda dealership. Toyota: $5.91.
    I walk the used oil, empty bottles, and the filter (wrapped in a used nitrile glove) down a path to a nearby Mr Lube. I catch the used oil in a big (reusable) container with large funnel attached, so there's no extra bottle to deal with.
    And hey, Toyota told me to. It is funny: head way up north to Alaska, and you're back on the US schedule, lol.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Don't do it Mendel!
    It's a trick.
    Next thing you know, you'll be chaining yourself to old growth timber and eating tofu spaghetti. At the same time.
    If the epitaph for planet earth ever becomes..."They Should of Stretched Their Oil Filter Changes Out"...then you can demonize me in hell.
    In the meantime? Mother Nature can hand me a new filter, it's time to change my oil.
  5. Mendel Leisk
    42,343
    And you'll change your oil by driving up on a curb near a storm drain, remove the drain bolt and let 'er rip. Tidy up by mopping up the area with a handy bald eagle.
    Apologies to the original author, the above is shameless plagiarism.
    NeilPeart likes this.
  6. Troy Heagy
    Troy Heagy Member
    1,218
    It's cheaper to buy the synthetic oil at Walmart on Sale for ~5 dollars per quart, and then take it to the dealer. Labor charge is only $20. Filter is about 5.
    So about 45 dollars total.
  7. DavidA
    2,349
    1,825
    Chicago western burbs
    This. My local dealer charges even less than that. I get my 0W20 at Wallymart in the larger container for around mid $20's. They seem to not even use all of the container too.
  8. Troy Heagy
    Troy Heagy Member
    1,218
    Here's the deal: The oil change shop is charging for 5 quarts. Even if your car only uses 3-and-half quarts, you are still paying for five.
    So you can save some money by pre-purchasing exactly what you need. (And you can save even more money by waiting for Walmart sales. I just acquired high-quality Mobil 1 for only 4.50 a quart.)
  9. JoeM(GA)
    JoeM(GA) Member
    40
    35
    Atlanta,GA
    You need to call around, no Toyota dealer here in the North Atlanta area is over $50.00 for oil change,and with a $20 coupon it was even better
  10. Mendel Leisk
    42,343
    If they're charging for 5 quarts are they giving you 1/2 quart left over?
    Our dealership does bulk oil changes. I've never used them, always DIY, but I'd speculate they'd write it up as 4.2 litres (4.5 quarts). I've seen their shop: they use graduated pitchers for oil.
  11. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    That's the way my dad used to do it! Except bunny rabbits' fur grabs the oil better than eagle feathers.
  12. misterrunon
    misterrunon New Member
    california
  13. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    If you don't know when (if) the oil was changed last, probably better off putting new oil in the car now than letting it sit in the jug! (y)
  14. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    The best shop to get oil changed is your own garage. It takes about 20 minutes, and 5 quarts of oil are about $25. Add $5 for the filter and crush washer. In the end you know when you changed it, if the filter and crush washer were changed, what kind of oil was used and how much was put in. With any shop you have no confidence of any of those things.
    Tande likes this.
  15. William Redoubt
    1,228
    1,174
    Tande likes this.
  16. William Redoubt
    1,228
    1,174
    Tande likes this.
  17. Mendel Leisk
    42,343
    At least once, I've just about put the oil filter housing back on without the filter. You can't trust anyone, lol.
    I would welcome a fool-proof design, say some mechanism that would prevent the housing from being screwed back on without a filter inside.
    William Redoubt likes this.
  18. William Redoubt
    1,228
    1,174
    They call that an oil filter. Where there is no housing. For a Prius, you replace the filter cartridge. Not sure of the pluses and minuses of the designs, but the Prius set up is more complicated to change, weighs more, and has more parts than a regular filter.
  19. Mendel Leisk
    42,343
    Still, it's easier to recycle, being just an (oil soaked) paper element. I'm sure there'd be a way, to make it goofproof.
  20. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    But you can easily inspect it for defects before or after use, and easily see how much and what sort of debris it has captured (except the microscopic stuff).
