Oil change door panel replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xliderider, May 27, 2023.
  1. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    @Mendel Leisk Do you mind sharing how you lift yours? (I’m afraid I have forgotten if already mentioned, or maybe I missed it). I drive our v up on a pair of Rhino Ramps. When folding forward the flap the edge will scrape the floor a little due to clearance. On our Clarity it’s a metal panel (6 screws and not very big) you remove which interesting surrounded by plastic, (plastic stays on the car).
    I have to venture they made the ‘12 model year panel more flexible plastic or something because I honestly see zero evidence for concern about folding it over. I’ll try to snap a couple of pictures I do believe there’s an indicator somewhere to pin it up, and of the crease. I was too lazy yesterday (day of rest for us) and this morning the ground is wet from rain overnight so hopefully at the latest tomorrow…
  2. Mendel Leisk
    42,343
    Ste
    "Oil Change Info" link in my signature pretty much covers it. (If on a phone turn it landscape to see signature.)
    jzchen likes this.
  3. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    Regardless of whether the flap is opened 90° or 180°, or whether using the original dubious "hinge" or an elaborately added actual hinge, folding the flap open requires the car to be lifted much higher than otherwise necessary. Making it conveniently detachable solves that problem.
    xliderider likes this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Agreed, will update after removable flag hinges are received and installed.
    jzchen and CR94 like this.
  5. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    That should work, but any simpler, easier-to-install method of holding up the front side of the flap would function equally well, unless you specifically need to have it hinged.
  6. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    Why not hinge it on the passener side?
    That way when it opens you can easily reach the filter and drain plug.
    If it only opens 45 degrees, you still have room.
    Or just remove it and have plently of clearence.
  7. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Still waiting for Hybrid oil to be delivered today, anyways got an appointment at 10:30 local time…
    Bumped into a picture of the inside of the panel, along with the associated tear/concern. There’s an arrow pointing to the pin hole and the words “FOR SERVICE” where you pin it up. Luckily mine hasn’t shown any sort of wear/tear/whitening of the “hinge” like this example.
    At this vintage (11 yrs old for ours) I’d probably pony up for a replacement if it started tearing, unless very expensive, say $200 or more…
  8. xliderider
    8,140
    3,280
    Honolulu, HI
    Got around to installing the lift-off hinges this weekend.
    I realize I'm not the first to do this mod. Here's another thread that details installing hinges that can be separated.
    Oil Change Door - Permanent Solution | PriusChat
    Since my undercover is old (2011 model year), the hinge area and some adjacent areas were starting to crack. I therefore spent much time reinforcing the area around the original hinge line on the panels that was ultimately cut through with 1/8th inch thick aluminum flat bar on both sides of the panel, adjacent to the original "hinge". I also put some pieces of 0.08 inch thick kydex sheet under the hinges to further reinforce the installation. There is also a piece of 1/16 inch aluminum flat bar running front to back along the midline side of the oil change access door. Everything is secured with pop-rivets and backing washers where needed.
    Since I installed the hinges hidden on the top side of the cover, the access door only opens about 80 degrees, but the panel is easily removed completely by sliding the door toward the passenger side.
    All original push pins that need to be removed (3 total) to swing the access panel down have been replaced by rivet nuts and thumbscrews/wing screws for a tool-free access to the oil filter housing and oil pan drain plug area. 20230603_155959.jpeg 20230603_160100.jpeg 20230603_160023.jpeg 20230603_160514.jpeg 20230603_164916.jpeg 20230603_163717.jpeg 20230603_163732.jpeg
    #28 xliderider, Jun 4, 2023
    jzchen and Georgina Rudkus like this.
  9. ASRDogman
    8,063
    4,086
    You people have way too much free time! :whistle:(n)
    Paul E. Highway and CR94 like this.
  10. xliderider
    8,140
    3,280
    Honolulu, HI
    I have a full-length Fumoto oil drain valve on the oil pan. It hangs down almost to where the cover is. I'd like to think that the cover would help prevent the oil valve from getting knocked off should something get under the car at speed.
    ASRDogman likes this.
  11. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Finally dragged myself to do an oil change, hopefully the correct pictures for the thread! I did take it for a good freeway run to get the oil hot/warm. Maybe that makes the plastic hinge more pliable?
  12. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    If you search for aluminum skid plate.
    You will see what I installed today.
    Here are a couple pictures.
    Get rid of the plastic and upgrade.
    Never lose a plastic part again.
    jzchen likes this.
  13. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Is that hole big enough that the oil from the filter doesn’t drain on it?
  14. AzusaPrius
    2,257
    942
    I did not think about that but will find out soon because it is time to change my oil.
    I only remove the filter once the oil has stopped streaming out and starts to drip.
    Shouldnt be that hard to wipe if it does.
  15. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
  16. xliderider
    8,140
    3,280
    Honolulu, HI
    Doesn't appear to be. I would probably design it with a larger removable panel in that area.
    jzchen likes this.
