For Sale Oil Change Door - SOLD
Discussion in 'Private Sales' started by Den49, Sep 10, 2015.
Thread Status:
Not open for further replies.
  1. Den49
    Den49 Member
    498
    272
    Maryland
    Sold my 2010 Prius and have an OEM oil change door for sale. It fits 2010 through 2015 Prius Hatchbacks is in excellent/like new condition and has two hinges attached. The hinges allow the door to be easily attached in place of a missing oil change door and open and close for easier oil changes. If your oil change door fell off and you want to replace it, this is what you need. I am asking $50.00 including free shipping or $40.00 local pickup. Below are pictures of the oil change door for sale. Send me a PM if you want to buy it.
    #1 Den49, Sep 10, 2015
    m.wynn likes this.
  2. RRxing
    RRxing Senior Member
    2,562
    1,841
    NEPA
    The way you did it will just allow the door to swing down, but it can't be removed. When using slip joint hinges they should be installed to allow you to completely remove the door, not just let it hang down and get in your way while changing the oil.
  3. Den49
    Den49 Member
    498
    272
    Maryland
    I purposely installed the hinges with a left and right so that the front of the door would be secure rather than removable. If the buyer wants a removable door I have an extra left and right hinge. One would simply drill out a left hinge and replace it with a right hinge to have the pins facing the same direction so the door can be removed. I can do this for the buyer if desired. However, I do not recommend this since the door swings open and can be secured flat up against the undercover which provides the same utility as removing the door and a more secure door when closed.
    This is the same door as pictured in post #1 of the below thread.
    Oil Change Door - Permanent Solution | PriusChat
    #3 Den49, Sep 10, 2015
  4. Den49
    Den49 Member
    498
    272
    Maryland
    See post #1 for price reduction.
  5. es114
    es114 Junior Member
    Chicago
    Still available?
  6. Den49
    Den49 Member
    498
    272
    Maryland
    Yes. Send me a PM if you want to buy it.
  7. es114
    es114 Junior Member
    Chicago
    How to PM? I'm interested.
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Choose 'Start a Conversation' from under their avatar picture.
  9. Den49
    Den49 Member
    498
    272
    Maryland
    Thanks Paradox.
  10. es114
    es114 Junior Member
    Chicago
    I just sent you a PM i think.
    #10 es114, Jan 9, 2016
  11. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    If you clicked on Start a Conversation like I pointed out, entered your text in the pop up window and then hit the Start a Conversation button in blue, you did it right.
    Also, I removed your email from your post above. Not the best idea to go sharing that in open forums, give it to the OP via the PM aka Conversation here on Priuschat.
  12. es114
    es114 Junior Member
    Chicago
    Mark - Thanks for your help
    Eric
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No problem Eric, hope you guys can potentially 'seal the deal'.
  14. Den49
    Den49 Member
    498
    272
    Maryland
    This Item has been sold.
Thread Status:
