oil change interval during Covid
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cutter44, Oct 5, 2020.
  1. cutter44
    cutter44 Member
    213
    MA
    I never thought I'd be asking a question like this.
    Since I bought my (used) Prius C more than five years ago, I've been changing the oil every 10k miles (Mobil 1 full synthetic, oem Toyota filter). Everything is fine, no issues. In fact, the last Blackstone lab report I had done a year or so ago said I could probably go to 11k miles between. Well, I'm happy doing them every 10k as it's nice and east to remember.
    Anyway, prior to all this Covid stuff, I was putting on between 22-25k miles per year. Now, I looked at my records and since the middle of March of this year, I've gone fewer than 3k miles. I still drive it every day; just not my usual 80+ miles per day commute. Last oil change was in the middle of December of 2019 at 140k miles. I have 147k miles on it now. So at the rate I'm going it will be another 7 months before I'd be due for my next oil change at 150k.
    Do you think there's any harm in waiting until Spring to do it? It's not a big deal, but there's also no point in wasting oil and my time if it really wouldn't be helping a great deal.
    Thanks for your thoughts.
    52,432
    there's no right answer, but most would tell you once a year. that's what i do, since i don't drive much anyway.
    spring is not an issue
  3. Mendel Leisk
    41,962
    If you follow Toyo USA's guideline, it'd be every 10k miles or yearly, whichever comes first.
    Maybe overkill, but I'd rather waste a little oil (and a filter), sleep easy.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Short, infrequent trips in an ICE move things into the "extreme" duty cycle for servicing. Go by time now not miles.
  5. cutter44
    cutter44 Member
    213
    MA
    Thanks, all. Makes sense. I guess my OCD will have to live with the odd OCI. :)
  6. mintprius
    mintprius Junior Member
    28
    earth
    if it sits, i still always do it every 6 months or so on all my cars. The reason is that oil is cheap, relatively speaking.
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Once a year if you don't reach the mileage in that time. Mobil also says so. (There's a little referenced engine warranty Mobil provides, similar to Amsoil, which also says once a year if mileage not reached within that time).
    moto g(7) power ?
  8. Kenny94945
    Kenny94945 Active Member
    859
    434
    Sausalito
    2016 Prius v wagon
    FWIW...with synthetic oil, in normal climates, with the car garaged.....
    I think there is low risk to seal swelling, acid build up, sludge accumulation
    So I would save the $60 dollars and change next Spring or every two years if low mileage.
    Blackstone Lab report is $30?
    That would have your true answers.
    Many say to change oil every year even if low miles.
    Again, with modern oil in a garaged situation, I think you can go with every two years for engine oil changing.
    +1 to the OP for using the Lab.
