Oil Change Interval
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Mar 13, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    One of the reasons you are NOT seeing the oil burning is likely because you are changing
    it more often. Before the oil can brake down.
    Sure is a lot easier, quicker, and less expensive then replacing the engine! (y):whistle:
    Grit likes this.
    52,801
    I would still do it because the stop start might be worse than a continuously running engine
  3. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Yeah i agree. Even thought the engine runs less these cars are hard on oil. Pretty much the entire line of 2ZR engines are known for being oil burners. Change every 5k. They have the weakest piston rings combined with godly compression numbers on these engines.
  4. Mendel Leisk
    42,293
    I believe!
  5. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    At 122k here. Any oil use is undetectable between changes as is the change of color. Aiming for every 10k or one year.
  6. Mendel Leisk
    42,293
    Maybe, if you're judging appearance of the oil by the thin film on the dipstick. Here mine, new versus drained, after about 4k kilometers. Both samples are Toyota 0W20. If it's not clear, the drained oil is on the right.
    PA Prius likes this.
  7. Paul Gregory
    Paul Gregory Senior Member
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    I'm not recommending that anyone stretch their oil changes, just that I do and without any apparent ill effects.
    No one will tell you to change your oil less frequently, I made that decision for myself.
