Oil Change Monitor? (Filter P/N?)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by DBLXX, Apr 11, 2016.
  1. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    I see where you can reset the oil change monitor but I can't actually find the monitor? I see that I can set my own personal monitor in the infotainment - is that the only place?
    If so - just set it to 5,000 miles? My old Civic did the whole 100% 90% 80% left thing.
    Also - any part numbers for the oil element housing wrench and a part number on a new element and rubber housing ring?
    Thanks fellas.
    Smaug1 likes this.
  2. Mendel Leisk
    38,726
    Not sure, but I believe the Toyota system is just counting mileage. Not adjustable.
    The Civic system was more advanced, seemed to be monitoring various factors, and (as you know) spelled out with a code what specific services were to be done.
    Smaug1 likes this.
  3. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    You could get that feature on, for example, a 2006 Chevy Cobalt, but it's too high-tech for a Prius.
    Smaug1 and Mendel Leisk like this.
    49,489
    just change it every 10k, no worries, you'll get notification every 5k.
    Smaug1 likes this.
  5. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    And if you prefer, for example, 8000-mile intervals, just reset the reminder at 3000, so it will wake you up at 3000+5000.
    Smaug1 likes this.
  6. Mendel Leisk
    38,726
    Canadian cars don't have the reminder, so no problem.
  7. priusgto
    priusgto Active Member
    193
    227
    Northern Arizona
    I just did my first oil change @ 3k miles. I bought this filter socket good quality and fit. The filter number is the same as the previus generation, 04152-YZZA6 and comes with the o-ring.
