Oil Change on 9/17+ learnings
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by BigBert, Apr 8, 2018.
  1. BigBert
    BigBert Junior Member
    28
    NH
    Did my extra 5000 mile oil change yesterday. Pretty easy.
    Very surprised to learn they’d changed to a spin on filter on primes as of 9/17.
    The right filter for late model primes is 90915-YZZF2 which is a very small spin on.
    I needed a different very small filter wrench. Size 2 3/8+.... my 2 5/8+ would not work (factory over tightened)
    Love the take off access door. Much better than gen 3. Use 10mm socket instead of a screwdriver makes it easier to remove screws.
    14mm for drain plug
    4.4 quarts 0w-20 Mobil1 synthetic.
    Ordered extra filters on eBay very cheap....
  2. illumiN8i
    illumiN8i Active Member
    184
    141
    Grand Rapids, MI
    2018 Prius Prime
    I noticed on my latest service report the dealer used 90915-YZZF1 instead of 90915-YZZF2 on my latest oil change. Last time they used F2. F1 is a slightly larger spin on filter. I wonder if the standard has changed again, or perhaps they used the wrong one.
