Oil Change Only at Dealership?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by shuyananah, Dec 29, 2014.
  1. tpenny67
    tpenny67 Active Member
    464
    402
    Massachusetts, USA
    Hmm, now that you mention it, one end probably is spring loaded already as that would be the pressure relief valve. But since it has resist normal engine oil pressure, it's probably strong enough to crush the filter a bit.
    One thing is for sure, looking around the web this is a problem with many cartridge filters. For example: Napa Gold 7082 (by Wix) | Engine Oil Filters | Bob Is The Oil Guy.
