Oil change with ramps?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by spiff72, Sep 12, 2013.
  1. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    The ramps are fine, then I put the jack under the center point in the rear to jack the rear, level the car and drain all the oil.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Because I have several of them in my screwdriver drawer, I use a couple small flatheads. They are the little ones with clips that you can put in your shirt pocket.
  3. Mendel Leisk
    42,377
    I mainly use a a repurposed tool, a paint can opener:
    They have a hooked blade that works well, hooking under the cap and prying. I also sometimes use a slim flat-blade screw driver, in particular if the fastener is jamming and I want to pry on both sides at the same time. If the head of the fastener pops up but it's still jammed, I'll use one of these under the fastener's collar, to gently pry up on the whole thing:
    The key fasteners longevity I've found, is to rinse them throughly in hot/soapy water, work the mechanism. It's mostly grit that jams the mechanism, causes them to break. Once in a long while the jaws will start breaking off, then I replace with OEM, purchase from dealership. It's rare though.
    Fostel and jerrymildred like this.
  4. El Dobro
    El Dobro A Member
    7,106
    3,282
    Nail pullers work, too.
    Fostel and Mendel Leisk like this.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I just use a small flathead screwdriver. There are probably close to a dozen clips and 5-6 bolts that hold the front to the bumper.
    Fostel likes this.
