Oil Change
Discussion in 'Gen 3 Prius Main Forum' started by markabele, Apr 20, 2012.
  1. markabele
    5,084
    1,782
    Nebraska
    Reading through my manuals on my brand new 2012 II and I was shocked to see that oil only needs changed every 12 months/10k miles. Wow! I can understand like 6k or 7k since the engine isn't running as much as a normal car but 10k?
    Is everyone waiting that long?
    So my very first oil change won't come until 10k? I thought you should change oil a little quicker right off the bat.
    Thanks for any insight and advice!
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Prius (and all recent Toyotas) does fine on a 10,000 mile synthetic oil change, which would be about 4 months in my case. Prius prior to 2010 use a 5,000 mile dino oil change, so I really do it every 2 months.
  3. Mendel Leisk
    42,355
    Most Stateside owners are comfortable with that. FYI: north of the border in Canada the official interval is still (roughly) 5000 miles, actually 8000 kilometers, or 6 months, whichever comes first. And no: climatic conditions do not change dramatically as you cross the 49th parallel ;)
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I could only make it to 8,000 before I just had to change it. :)
    On top of that, it only uses ~ 4qts of oil.
  5. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    There's a long thread under Maintenance about the first oil change. I did my first @ 1500 miles, then @ 5000 miles and 10k miles, and I've done 10k oil changes since. I get my used oil analyzed by Blackstone Labs, and my engine is in great shape. BTW, I'm at 35k miles now.
    I use Mobil 1 and TRD filters.
  6. markabele
    5,084
    1,782
    Nebraska
    anyone have a link to that thread?
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Actually...there's more than one thread--in fact, this is one of the most frequently discussed topics here (and on every other car forum I've participated in). Try a search.
    FWIW, I always do a first change at ~2K miles, then every 5K miles. Call me crazy, but I don't like to wait 10K miles to change oil & filter.
  8. El Dobro
    El Dobro A Member
    7,106
    3,282
    Does Toyota run their engines, change the oil then install them?
  9. schorert
    schorert Member
    127
    51
    mass
    Shortening the oil change interval has a demonstrated benefit, it lubricates and relieves stresses in the brainpan of the prius owner. As prius owners are all out of warranty, there may be some increase in their longevity. There is no demonstrated benefit to the vehicle itself. Economical and environmental benefits of the vehicle are offset fractionally by wasting oil.(there is a carbon expense in producing oil, trasnporting, then disposing).
    Both BMW and MB have first oil changes at 15kmi.
    Most modern cars are designed to be basically maintenance free. To people who have owned many older vehicles, and maintained them themselves, this is troublesome. The one thing owners have control over is oil changes! We're down to 0-20w once every 10k mi, I've urinated thicker than 0-20. It really won't be long until the oil system is sealed completely. I personally believe the only reason it's still user serviceable is customer reluctance to buy a car they can't do even this little bit of maintenance on.
  10. El Dobro
    El Dobro A Member
    7,106
    3,282
    This is my point. Other manufacturers run their engines and change the oil before they install it. When they say don't change the oil until until x miles, they mean it and anything sooner is a waste of oil. I changed my oil at 10,000mi. and will again at the next 10,000mi. The engines and oils are improving every day and there's no reason to second guess the manufacturers.
  11. schorert
    schorert Member
    127
    51
    mass
    Mercedes doesn't even put drain plugs in vehicles anymore(not in my 08 anyway), so DIY'ers have to purchase an extraction pump. Oil changes are done through the dipstick tube, oil filters are mounted on top of the engine.
    I'm very confident that every manufacturer runs engines prior to install, drains oil and refills with synth. that could be just minutes of runtime.
  12. Mendel Leisk
    42,355
    Toyota's oil change interval varies wildy, depending on your country. There's a reason.
    Depending on your mpg, in 5000 miles you'l consume maybe 80 liters of gasoline. Versus 4 liters of motor oil for an oil change, responsibly recycled?
  13. Kingetula
    Kingetula New Member
    24
    In a house
    I was about to ask the same thing before I saw this post. In my manual, it states oil change at 5,000 miles. I asked Toyota and they told me 10,000 using 0-20 oil they have.
    I started thinking... If I get free service for 25,000 miles maybe this is their way to save money! Instead of 5 oil changes now, they only have to do and cover 2 oil changes. That can really add up in big savings for Toyota.
    On the other hand I have watched programs where the 3,000 mile oil change was not really needed in these newer cars and was a way for companies to make money.
    I'm a firm believer things get done or are not done correctly because of money. (How to make it or how to save it).
    A new engine should not wait 10,000 miles for its first oil change IMO. I will be changing mine at 5,000 and at 10,000, then I will go along with every 10,000 miles.
  14. stream
    2,977
    452
    Long Island, NY
    I seriously doubt Toyota does that--or any mainstream auto manufacturer, for that matter.
    What is your high degree of confidence based on?
  15. Kingetula
    24
    In a house
    I think he might be assuming they run it to get the metal shavings etc that a new engine will have as it breaks in and that maybe he thinks "Toyota" cleans those metal pices out by doing an oil change right away. I could be wrong (On what he really means) but that is why I will be changing mine at 5,000 and probably should do it in the first 1,500 miles. I am curious about the guy who sends his oil off (Forgot his name) but does that company tell you if there is metal of any type from breakin in the first oil change? This might change my way of thinking all together.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Sadly we do not know where in the universe you are, but in the US, it is 10,000 miles/1 year.
    (Should you ever hope to use Priuschat as a resource, accuracy to the state/province level will aide your helpers.
  17. Kingetula
    24
    In a house
    Haha, living off the radar. USA
  18. El Dobro
    El Dobro A Member
    7,106
    3,282
    Correct, and for where I am, it's 10,000mi.
  19. El Dobro
    El Dobro A Member
    7,106
    3,282
    VW runs their engines and changes the oil before the engine is shipped. The oil changes in their diesels in the USA is 10,000mi. It's much longer in Europe.
  20. krazypriuslady
    232
    metro Wash DC
    I have asked at the dealer several times about metal shavings and doing an oil change at 1500 miles. They have replied every time that it is not necessary. Needless to say I trust the collective wisdom here more than them. It would not be covered under the free oil change policy.
