1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I just spent the last half hour reading a bunch of posts about oil changes and levels and such. Surprisingly, not one post about the condition in which to check the oil level, as stated in the owner's manual -
    at normal operating temperature, wait 5 minutes or more, then check the oil level.
    I will be noting how much the oil level changes between a cold check and normal operating temperature check. I am virtually certain the level is slightly lower at normal operating temp than when the engine is cold.
    The same thing happens on my motorcycle - when cold, the oil level fills up the check window. When running the engine for several minutes, then waiting 3 minutes, the oil level is halfway up the window.
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    I usually check my oil on every other fuel stop (about once a month). I haven't seen any discernible difference in the level after I fill it up after a oil change or when I check it while adding fuel. I haven't seen the level drop any between changes either. I have 25k miles and I'm using the recommended 5k OCI using either M1 5W30 or for the last two changes, M1 0W30.
  3. philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    575
    107
    Los Angeles
    it's been almost a year ... what did you find?
