Oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OZ132, Jun 2, 2009.
  1. LINKSTER
    LINKSTER LINKSTER
    los Angeles
    The manual recommends 0W-20. Mobil I would seem to be the best choice?
    Would like to do the first one myself, probably early, to get the new engine metals out.
    Any advice?[/QUOTE]
    I was in my Toyota dealership here in LA today and yes they want you to use 0W-20. You can use a regular oil once, but the next change needs to be OW-20. I went to a local parts store and MOBIL ONE sells 0W- 20 and OW-30 for around $6.25 a quart. Good oil is critical to a well functioning engine and cost should be the least of your concerns. Don't "game" this one. I suggest that you change it a 1,000 miles and when ever the schedule requires it.
    BTW....... while I was there, I got the tech to change the reverse beep to once and the seat belt to zero. He could not change the door opening to the driver and passenger side. Darn
    Linkster
  2. web1b
    web1b Active Member
    817
    52
    Even if you find some metal debris in the oil, it doesn't mean it isn't supposed to be there or is damaging or reducing the life of the engine. In some cars, some of what you may take it upon yourself to pronounce as "debris" is really intended to stay in as part of the break-in process so parts of the engine are properly polished/worn and actually does "break-in."
    People send oil out for analysis on a brand new car and when the results come in say "OMG! Metal particles were found! I'm going to wash that all out and save the engine!"
    Some over zealous oil changers may be preventing the engine from breaking in as designed.
  3. wave_slider
    wave_slider New Member
    201
    26
    the aloha state
    Really??? I thought the metal particles were bad...
  4. web1b
    web1b Active Member
    817
    52
  5. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    I think that's just so funny, I almost peed myself. Toyota dealerships have given folks very cute responses (Synthetic oil voids warranty) now they're requiring a synthetic oil
    But still with one of the shortest oil change intervals in North America
  6. jayman
    13,439
    639
    Winnipeg Manitoba
    How many oil analysis labs will flag an oil sample - on a brand new engine - as "bad?" The only exception is if the oil has really degraded, eg no TBN, excessive shear, etc
  7. wave_slider
    201
    26
    the aloha state
    Interesting. Thanks for the link. It makes sense. I have always used synthetic oil, but have changed according to the manufacturer's spec's. I figure though it costs a little more, it's better for my engine and I won't run into any problems with warranty.
  8. gofast
    gofast Member
    151
    25
    Denver Colo.
    I do no agree with any of this especially the over zealous oil changes hindering the break in and metal debris helping break in and I have extensive experience in building and breaking in engines.
  9. snijd
    snijd DIY or die
    243
    52
    PNW
    This thread reflects the very wide range of prevailing philosophies about oil changes. Here's what I noticed and wonder about:
    1. Some change their oil cold, but I've always read that changing it hot is best. If there's merit in cold oil changes, what is it?
    2. Some have stated that suspended particles aid in break in. Is there any science to back this up?
    3. Evidently a few new car makers fill their cars with break-in oil at the factory. Does Toyota? (I believe no one has suggested this, but I'm not sure)
    4. If Toyota fills the Prius with 0W20 at the factory, what harm is there in an early change with the identical oil type? (unless you subscribe to the idea that suspended particles are helpful to engine break in)
    5. Toyota doesn't recommend an early change to the CVT fluid, but considerable UOA data, including my own, suggest this is an excellent idea. This leads me to believe Toyota isn't always as conservative about fluid changes as some have asserted.
    Based on what I've read so far, I'm leaning toward a 1,000 mile initial oil change.
  10. web1b
    web1b Active Member
    817
    52
    There are always going to be people with an obsessive compulsive desire to change oil by a certain time no matter if that time conflicts with the manufacturers instructions. Others who are recreational oil changers who just enjoy tinkering and changing oil as opposed to gardening. Then there are others who have just had this beat into them from their fathers and forefathers or their own experience from decades ago. Nothing anyone can say will ever change their mind.
    On one hand they ask for scientific evidence to prove what they don't want to believe, but on the other hand point to anecdotal evidence to prove what they want to believe.
    I actually think 5,000 mile synthetic oil changes are probably excessive for the Prius, but if I were to buy a Prius, I would still follow the recommendation even after the warranty expires because that's what they recommend. This increased maintenance cost and inconvenience will be a factor in whether or not I choose to buy a Prius, but I won't say I know better than Toyota and make up my own maintenance schedule.
  11. Mr. Bill
    Mr. Bill Generation III
    86
    222
    Dunedin Florida
    Hello all,
    Changed my oil today - went without any issue.
    I created standard work including pic's if anyone is interested of the process.
    email me at [email protected] if interested
    The total process took less than 45 minutes considering I didnt know what to do
    Mr.Bill
    PS using Mobile 1 5W 20W (or similar) - replaceable oil cartridge - 4.4 qts and you are good to go.
    This is my first change at approx 1200 miles.
  12. gofast
    gofast Member
    151
    25
    Denver Colo.
    I jacked my Pruis up today to look around and put a magnetic oil plug in it. There are three plug clips that need to be removed. Two that are black and one has a Grey button.Pry the inside button out untill it stops with a little screw driver. Note which one is which and then bend back the cover towards the front. It does not come off it bends back. YES it a cartridge but its no big deal.
    I rebuild engines and dyno them so I would not say I'm some ignorant fool. The magnet and oil will tell me plenty in 1000 miles. Also I am very impressed that this Prius has a tubed header exhaust instead of a cast iron exhaust manifold. Here is a link that shows the process and also my drag bike at Bandimere Speed Way.
    http://picasaweb.google.com/palsers/Barryspics#5357788072818767650
  13. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    All three generations of Prius have had the tubed headers.
  14. web1b
    web1b Active Member
    817
    52
    Wasn't there a thread in this forum a few weeks ago that said you are specifically not to use Mobile 1 oil? Was that debunked?
  15. gofast
    gofast Member
    151
    25
    Denver Colo.
    Whoever said that does not know what there talking about. Mobile 1 is some of the best oil in the world.
  16. jayman
    13,439
    639
    Winnipeg Manitoba
    I usually try to smack people like that. Very satisfying
    Please consider posting your photos here
    As far as the cartridge filter, did you loosen it up first to let the oil drain around the flutes on the side, or did you just unscrew it all the way and let it drain out?
  17. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I found this post on another forum about the Mobil 1 thing. See the 7th post down.
    2010 Prius Oil Change - CleanMPG Forums
    Seems reasonable and is something that could be verified with Toyota.
    Peter
  18. jayman
    13,439
    639
    Winnipeg Manitoba
    If the 2010 Prius engine requires a uniquely formulated 0W-20 (To minimise engine wear, improve fuel economy, etc), then according the the Magnuson-Moss Warranty Act, it must be provided FREE
    Anybody want to take bets that most Toyota dealerships will use whatever generic crap 5W-30 they have sitting in the rusty tote bin out back?
  19. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Every oil advertisement I've seen say it's a uniquely formulated blend. They all are different. This one just happens to be 0W-20. I started using it 3 years ago in the TCH. the dealers stock it.
  20. jayman
    13,439
    639
    Winnipeg Manitoba
    If the 2010 Prius requires a uniquely formulated oil, Toyota has to provide it free
