Oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OZ132, Jun 2, 2009.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Good job John this is just what's needed. OK, now I'll nit pick just a little.
    There are a couple or places where the text under the photos may need to be reworded slightly:
    Page 11, change " . . . . above to the oil pan, on the passengers side . . . ." to read " . . . slightly above and behind the oil pan on the passengers side . . . "
    Page 12, change " . . . this is exposed part . . . " to read " . . . this is the exposed part . . . "
    Page 10, 12 ft lbs for the drain plug seems a bit low? I have seen two other numbers listed, 23 ft lbs and 27 ft lbs for the Corolla 1.8 liter engine which should use the same torque values as ours. Some of the posts on this site for the Gen2 list 28 ft lbs for the drain plug. I don't know if any of those values are correct or not. Also there is no torque value listed for the oil filter cap, I have seen 18 ft lbs listed on the Corolla site, that seems about right.
  2. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    That would be nice, but it's probably not going to happen.
    The lighting was horribly difficult to work with and everything was covered with oil (not good for a digital camera). The contrast with the cartridge, plus dealing with an audience (since you can't just work under a 2010 Prius and not stir attention of the neighborhood), is too much. Also, the next change won't be until October or so.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I presume some arrows to show where the retaining screws/plugs for the oil drain cover are located will be included in the final version?
    Otherwise looks pretty good.
    I might suggest an expansion of the first part where you mention overfills, but perhaps make that an entire paragraph on the multiple benefits of doing your own oil changes.
    Did you comment on documenting the maintenance manual and keeping oil and filter receipts in case of future warranty concerns to show proof of proper maintenance?
  4. john1701a
    12,820
    5,305
    58
    That's the stuff I'm looking for. Choosing photos and figuring out what-to-say drained the how-to-say energy from me. I'll step back and let others mull it over for awhile.
    I wasn't sure what to expect. That was my first time seeing a cartridge and hadn't ever worked with a sealed engine like that. In fact, I thought it was just thick plastic. I didn't realize it would have more 2 layers of insulation attached to it. I hadn't thought about how much under-the-car room it would use either.
    2 people like this.
  5. aliqueen
    aliqueen New Member
    Toronto
    Thank you for the very comprehensive instructions.
    Just a side note, will it be advisable to warm up the engine before the oil change? Also, do you warm up the engine after the oil change and then check the dip stick?
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just from my own experience, it is best to change the oil with the engine slightly warm (not hot). If hot, let is set for say an half hour to an hour.
    After the change, start engine till the check oil light goes out (just a few seconds). Then check the dipstick.
    Hope that helps,
    Peter
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Ok, just curious. Mobil 1 0W-40 and Toyota oil filter with my FJ Cruiser, after 7,500 miles the lab results came back good for much longer. It's a high quality oil
    Looks good. Perhaps use PhotoShop or another image editor to add arrows to where the push-pins hold the plastic cover up.
    The rubber mallet can also be used to beat the old cartridge senseless if it splashes oil all over you. Or, you can use the rubber mallet to whack anybody nearby who is bothering you
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    That happens to me after heavy drinking
  9. tumbleweed
    4,067
    692
    Eastern Oregon
    I just read through the oil and filter replacement procedure in the maintenance manual on the TIS site, "2ZR-FXE Lubrication: Oil and Filter: Replacement (2010 Prius) Doc ID: RM000002UQM01X" last modified 7/21/09.
    I noticed the oil requirements for the U.S. and for Canada are different. For U.S cars it requires 0W20 no substitutes are listed and nothing about using 5W20 every other time. For Canada it lists a choice of 0W20 or 5W20 also with no mention of switching back and forth.
    Don't U.S. Prius and Canadian Prius use exactly the same engine? Why the difference in requirements? Why is it OK to use 5W20 oil all the time in the colder of the two countries?
    New Subject:
    John1701a, the torque values listed in that document are 18 ft lbs for the filter cap and 27 ft lbs for the drain plug.
  10. john1701a
    12,820
    5,305
    58
    Thanks for the comments. Summer has finally arrived here, so there hasn't been much of a draw toward hiding inside on the computer lately. (Must play with Prius!) Meanwhile, I see lots of downloads of the draft copy. (350 in 2 days!) Looks like this DIY oil changing remains a hot topic of interest. Cool.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes thanks to you!
  12. jdel
    jdel New Member
    49
    John,
    Great job as usual. One note, the proper oil level on the dip stick should measure 4mm. 6mm would put over full if measuring from the end of the dipstick
    John
  13. john1701a
    12,820
    5,305
    58
    I figured someone could verify for me. Thanks!
  14. john1701a
    12,820
    5,305
    58
    The wording is: "The ideal level is about 6 mm (one-quarter inch) below the full mark."
    Should something else be mentioned or in a different way?
  15. john1701a
    12,820
    5,305
    58
    By the way, using precisely 4 quarts worked out fantastic... so well, I'd say that qualifies as an clever improvement from Toyota. The mechanics can't screw up measurement if they are using bottles. There's no guessing anymore. You can hit the ideal level dead on just by pouring the entire contents. Sweet!
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Tom, there are odd differences with servicing Canadian and US market Prius cars, such as the Canadian market cars having a CVT drain/refill schedule.
    On average, the Canadian climate is much more harsh - colder - than the US climate. The Prairie provinces alone resemble most of Alaska in winter.
    I would absolutely use a 0W-xx in Canadian winters
    Oh ye of little faith.
    If there is a way to fubar something, don't worry, they'll figure it out
  17. jdel
    jdel New Member
    49
  18. 04PriusOwner
    04PriusOwner New Member
  19. concertinajohnnyboy
    104
    Minneapolis
    So, is Mobil 1 0W-20 acceptable? Or, must we fill with Toyota oil? I seriously doubt that all Toyota dealers in the USA have "Synthetic" 0W-20 oil.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    To the letter of the Owner's Manual, yes. That said, we all have been hoping to squash the rumor that it was not acceptable (an internal Toyota service memo). I think we are past that now. I also think others including myself hope Toyota would consider increasing the service period (5K miles/ 6months) since most if not all 0W-20 are synthetics and or blends that cost that much more.
    Peter
