Oil Changed, OverFilled
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by progamerz, Dec 26, 2021.
  1. progamerz
    progamerz New Member
    usa
    Did an oil change on 08 Prius , mobile 1 oil wix filer. upon filling it with oil he top line slightly . i drained some oil and the fill level came down half way. I refilled a drop of oil and it was over again... at this point i drained the oil and took the filter off.... the dang car said it was full of oil still.. top notch on stick
    let the car sit for some time checked oil.. with no plug or filter .. said displayed it was still full.
    at this point i poured more oil in and it raised the oil level even further up the stick.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    It’s ok if it’s over the full line a little. Normally takes exactly 3.9 quarts with new oil filter. I routinely ran my 07 with four quarts and at 175000 miles still did not eat any oil.
  3. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    It sounds like you're not wiping the dipstick after removing and redipping?
    You're not going to get a reliable reading if the dipstick is not clean, to begin with.
  4. JC91006
    16,672
    8,518
    Look on both sides of the dipstick, go with the mark that measures lower on the reading. That should be accurate
  5. progamerz
    usa
    just to follow up .. it appears the dipstick can be insert wrong... if it is it read the oil levels wrong. ... i ended up twisting it around and the oil read out was correct... just fyi
  6. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Lol that’s silly.
  7. dolj
    dolj Senior Member
    8,209
    4,180
    ... and yet it is true.
  8. douglasjre
    douglasjre Senior Member
    2,094
    701
    Null, NL
    Why are you so focused on this
