Oil changes at the dealership?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kenlav, Aug 15, 2024.
  1. kenlav
    kenlav Junior Member
    32
    Is it recommended to get oil changes at the dealership? I've read online that some people are highly against it, because they don't use top tier oil or something, and they use their own house brand.
    I found a dealership service coupon online; $199 for 5 oil changes and tire rotations including full synthetic oils. Im tempted to buy but not sure of the quality.
  2. PriusCamper
    PriusCamper Senior Member
    13,411
    5,413
    Pacific Northwest, USA
    If its free than its fine... That's what dealerships are best used for. But if you expect anything more than freebies, warranty repair and recall work from Toyota Stealership than you're an unwittingly about to watch your bank go down significantly by way of all their various scams. As in they use the oil change to sell you stuff you don't need.
    52,785
    Dealership should be fine, but check the oil level before you leave
    Merkey likes this.
  4. Merkey
    Merkey Active Member
    328
    300
    Birmingham, Michigan
    I buy synthetic oil on sale from Costco, Walmart, Meijer etc. The dealer gives me a good discount to use it.
  5. Kenny94945
    Kenny94945 Active Member
    863
    439
    Sausalito
    2016 Prius v wagon
    That's a good deal IMO.
    The only mechanical risk is the torque of the oil filter canister, damage to the undercarriage fairing, or jacking points I suppose.
    If a Toyota dealer, I would assume the correct Toyota oil filter is used and a correct viscosity synthetic oil.
    Brand of oil may not truly be a risk.
    Of course, once your car is in the shop, dealer service departments can recommend additional services, such as brakes, coolant flushes etc.
    If you are on warranty, again seems like a good deal.
    If off warranty and the engine fails because of an engine oil-related issue, that's another risk.
    Good luck with your decision.
