Oil changes every 10,000?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bnaccs, Feb 22, 2011.
  1. bnaccs
    bnaccs bnaccs
    191
    Colorado
    Should I really wait for 10,000 miles for my first oil change. I am used to oil changes every 3,000 miles. My trips are often short, 6 miles each way to work. The maintenance guide then says 5,000 oil changes are required for short trips in cold weather. Will my Toyota care cover this if I tell them my trips are often short in cold weather. Any one waiting the full 10,000 miles before changing oil. Isn't the first oil change suppose to be sooner for break in purposes? Any thoughts would be appreciated.
  2. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    I had my first at 1K, second at 5K, and many every 5K after that.
    I would recommened a 1K, 5K and then every 10K after that
  3. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    1st oil change at 5K and every 10K after that (15K, 25K, 35K, etc.). That way, you don't get killed on the 30K maintenance "special" from taking it in at 30K.
    You're not required to inform them the duration of your trips.
  4. Mendel Leisk
    38,253
    The Canadian schedule still says every 5000 miles (8000 km in Canada). Even if they did change policy, make it 16000 km, personally I would stick to 8000 km. I will be doing my own, fwiw.
    Just my personal preference: I will also be doing the transmission fluid much more frequently than Toyota's recommendation.
  5. frank4
    frank4 New Member
    Timmins
    Been reading lately about oil monitoring technologies to help extend oil change intervals.
    Oil monitoring systems look at crankcase temperatures, moisture, and combustion chamber events while the engine is in operation. The best systems can measure the serviceable life of a car’s engine oil to within 10%. The result of the adoption of these technologies is that with normal vehicles use, many manufacturer had adopted a new recommended figure of 7,500 miles between oil changes.
    In fact, the best synthetic oils used to flaunt 10,000 km changes but probably because of warranty and legal concerns, this extended change interval has ceased to be advertised.
    However to be on the safe side, DIY owners would be better off adopting a 5,000 mile oil change interval.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    The oil change interval has been 10k miles in the UK and Europe for decades. Infact Toyota is regarded as quite low at 10k miles - some manufacturers recommend oil and filter changes on petrol engines every 12k, 15k or even 20k miles.
    So long as you use the correct, fully synthetic oils you should be ok. Some of my colleagues run their cars upto 250k, 300k miles using the recommended change intervals with no engine issues.
  7. wildbottom
    wildbottom New Member
    99
    I thought farther trips(highway) allows you to prolong your oil service interval. Heat activates detergents that cleans the engine.
    Plus at higher speeds, more cool air is forced into the engine's cooling system as long as the ambient temp is not extremely hot(100 degrees F). Then you shouldn't drive too far.
    It's how long it takes and not just how far your trips are. If you have lots of stop and go traffic, then the Prius's ICE never gets a chance to warm the oil/engine in a 5-mile trip and esp. if the temp is colder outside. Then you have dirtier oil and engine.
    That's why pre-owned cars with more highway commute miles are preferred over ones doing time in urban driving. Plus oil standards and technological have progressed substantially while some newer vehicle owners still change their engine oil at 3K intervals.
    Finally, you need to assess how dusty your enviroment is. The dustier it is, the more possibility for minute particles to go thru your intake/filter and into your ICE/oil. You should check your air cleaner every time you change your oil. It's a good precaution to take since you can use a Air/Dust Can to blow debris off the filter element until you reach the replacement interval which is 15K and earlier if it gets dirty sooner.
    My Guidelines:
    1. Miles driven in Urban(stop and go)
    2. Hotter Temp (oils break down faster)
    3. Colder Temp (need sufficient ICE drive time to warm oil)
    4. Dusty or Dirty(pollution has more particles) environment
    5. Type of Oil and Oil filter element(paper which is found in OEM vs. synthetic which last longer)
    6. Color of your oil on the dipstick (make sure it's not black).
    I used to change my oil around 7-months or 5K and depending on how much city/highway driving I do. I live and drive mostly in mild climates. Now I do 7K changes ever since I've been using Mobil 1 Syn (5-quart Jug for $23 at Wal-Mart) and it stays cleaner for a bit longer.
  8. wildbottom
    99
    Well, Honda has been using oil monitoring technology in their vehicles ever since the 2003.
  9. Mendel Leisk
    38,253
    That's not really the case: the car's computer monitors several factors: mileage for sure, and very likely coolant temps, maybe several others such as number of starts, ambient temp, mean rpm, and so on. And then counts down the oil life, in 10% increments. But that's it, no direct oil analysis.
