Oil Charge at 7500 or 10k??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MPGnutcase, Aug 20, 2013.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    The engine generates ALL the power for the car, both the ice and the EV. Doesnt matter how many cycles that battery makes in 10k. All the energy comes from gas in the end.
  2. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    well this is true enough if you live on the great plains ... otherwise you can harvest/reclaim and store kinetic energy what other cars can not do ... (climbing the hills goes the same for hybrid and nonhybrid)... there is still no other powersource though
  3. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    True, you can reclaim it, but the engine made it in the first place. My point being: No matter what speed or what terrain you drive, I bet the engine runs about the pretty much the same amount of time for a given 1,000 miles. If you drive 100 mph it runs 10 hours, If you drive 50 mph it runs maybe 10 hours on electric and 10 hours on engine. Same 10 hours, but less wear driving slower? Anyone have a different viewpoint?
  4. jnet
    jnet Member
    196
    32
    I get much better mpg if I drive slower like 45 mph. I could easily get 65 mpg. Just pretend that I could drive like this all the time, I can't image that I should follow the same oil change schedule as someone who drive 85 mph all the time. That's why I think oil change based on fuel consumption seems more logical.
    Even though the electricity is generated from gas, the Prius still have two power sources and I could use just electricity at a given time. On a slight down slope, I could run on EV for a very long distance without using gas.
  5. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Mostly all true!
  6. richard13
    richard13 Junior Member
    65
    Mill Creek, WA
    Outside of warranty I guess it's Thunderdome. :) My personal feeling is that 10K seems about right for the way I drive and the fact that it's a hybrid. Just sayin'.
  7. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    It's hard to say what a good oil change interval is. I wonder about the environmental impact of manufacturing synthetic vs drilling for regular oil.
    I heard 0-20 regular ( not synthetic ) oil is now available. I'm thinking of getting some if it is cheaper.
    I remember telling my dad that the oil change interval does not matter just miles drive. He doesn't drive much per year. His car had a slow leak that went unnoticed. His car ran out if oil and the oil light came on. It only had 70k miles. The engine was not ruined but I learned that the interval could help people who have slow oil leaks and never check oil level.
    Turn off signatures in Tapatalk Tapatalk
  8. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    There's no contest though about how much better synthetic is when it comes to cold starts. And if you want both oil & engine to last longer, it tends to make sense spending the extra for that.
    Also, consider how long 4 quarts of oil will last you verses 4 quarts of gas. You'll consume the gas in about 50 miles. The oil will provide service for 10,000 miles... then it will be recycled.
  9. orenji
    orenji Senior Member
    5,887
    3,488
    Go with what Toyota states, they are the experts, and must have researched this and believe 10K miles is best for all types of normal driving, now if you want to do it sooner then do so, it will not harm anything.
  10. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
  11. orenji
    5,887
    3,488
    Oil will always be drilled for, so don't lose any sleep over it.
  12. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Maybe. Or a good interval is greater than 10k miles but they wanted to help their dealers keep their service revenues.
    Mike
  13. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    I don't put more than 15K/year on my car, so I just change the oil myself twice a year, once in the Spring, once in the Fall.
  14. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    It depends on where and how you drive, how short are the trips(does the engine and oil get enough running time to heat up ?), how humid ,warm, cold is your climate ?
    I live in a cool dry northern climate. My shortest trip is 40 miles, so the oil gets warm. At 10,000 miles, the oil in my 10 Prius still looks almost new, just darkening enough to make it easier to see on the dipstick. The engine uses no oil between 10,000 mile changes.
    !0,000 mile changes work fine for me.
  15. Jon Hagen
    336
    136
    North Dakota
    And synthetic oil is either made from natural gas,(PAO base stock) or hydrocracked mineral oil, so all oil comes from drilling for oil / gas.
  16. nzlpablo
    nzlpablo Junior Member
    17
    Wellington, NZ
    Sorry for replying to an old post but I put black tape over my 92 Honda Prelude's Check Engine light for the last couple of months. I'm not sure what's wrong with that? The orange light is very bright and distracting, and the tape is cheap, quick fix that anyone can do. It doesn't sound like you've had experience doing this fix so I don't think you're qualified to speak to it tbh.
    Seriously though, my CEL lit up for a faulty knock sensor. do not know about Toyota but CEL's only come up in old Honda's for emissions-related things, not actual hardware faults in the engine. It took a few weeks for a replacement sensor to be delivered from eBay so I "solved" the CEL problem in the mean time :D
