Oil Consumption. 5W-40 ok?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Christian_cool, Sep 26, 2016.
  1. Former Member 68813
    3,524
    983
    US
    it's cool how the oil education progressed here. a few years back the standard response was "0w20 or your engine blows apart."
    Maroon, m.wynn, orenji and 1 other person like this.
  2. Hybrid++
    Hybrid++ New Member
    Brussels
    Hi Christian_cool and all other Prius 2010 drivers with excessive oil consumption.
    I have the issue of excessive oil consumption with my Prius 2010 and I would like to know what is your feedback on the possible use of 5W-40 like Shell Helix Ultra ?
    I think that I will try the same type of oil but I wanted to know first what is your feedback about it after 2 years ?
    Many thanks
    O.
  3. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    On some cars, they use oil due to the piston rings being carboned. Always use Tier 1 gas. Someone on the board used 4 continuous tanks of gas with Techron Fuel system cleaner additive and it stopped his consumption. I assume due cleansing of the rings. It is worth a try.
  4. MPG Student
    MPG Student Junior Member
    After reading threads like these, I decided to give Mobil1 5w-40 a try. 07 with 169k miles. about 49 MPG so far, but should be 51. Maybe oil needs to break in a little. Will report back here... I even removed 100lbs of comic books from the trunk :( Engine is burning about a quart every ~5k miles.
    #24 MPG Student, Nov 15, 2022
  5. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Hey man you shouldn't even worry about burning a quart every 5000 miles. Thats considered good. lol
    Just to ease your mind.
    Also, 5w-40 is fine. May or may not be any different on oil consumption than whatever is spec'd for a gen 2 so thats up to you to figure out.
  6. abdullah arslan
    189
    79
    10k interval not a reasonable thing for 10-11 models, max 5k or 6 months otherwise burning oil and other following issues inevitable. If I were you, I'd try mobil 1 0w-30 too And after a few short term oil changes, it may go back to normal oil range if things getting more cleaned, of unless a physical damage on cylinder(s)
    Paladain55 likes this.
  7. Paladain55
    414
    172
    The South
    Sure makes you wonder doesn't it. The 2010 Prius came out with a 5k oil change interval. Those geniuses changed it after the car came out. Thats why the oil minder comes on every 5k. I would say to do 5k or less oci on all cars as oil is cheaper and easier than motors.
