Oil Consumption Problem -- Dealer thinks piston issue -- anyone else experience this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amethyst_sky, Jun 22, 2015.
  1. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    There are many things that cause engine wear (which is normal by the way), but the number one way to reduce the rate of wear is to maintain level with quality product and change the oil/filter regularly...perhaps more regularly that the manufacture that wants to sell you the "next" car (or charge you to repairs) wants. End of line.
    52,855
    who revs their prius engine?:p
  3. madmaxvol
    madmaxvol Junior Member
    Knoxville, TN
    Some may have had their transmission in "B" position when going down long descents...I know someone who did this, and the prius screamed till I reached over and shifted it into D, then told him about the harm in overreving an ICE.
  4. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    But you simply can't overrev the engine in a Prius, the computer won't let you. The only way you can overrev an engine these days is to do the following:
    1) Buy a car with a manual transmission
    2) Rev the engine to redline in third gear
    3) Shift to fourth, but accidentally get second instead
  5. bisco
    52,855
    not sure about gen III, but i think in gen II if you put it in neutral and back into drive at high speed, there is a possibility.
