oil consumption vs length of oil change interval
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Former Member 68813, Jun 4, 2015.
  1. no consumption, OCI near 5,000 miles or less
  2. no consumption, OCI near 10,000 miles or more
  3. consumption, OCI near 5,000 miles or less
  4. consumption, OCI near 10,000 miles or more
Results are only viewable after voting.
  1. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    Great data! I couldn't help noticing that at 1qt/5K, by the time you reach 16k miles you've already replaced 3 of the 4 original quarts. If you get to 20k between changes with a good oil analysis, I think you can skip oil changes altogether, keep it topped off, and screw on a new filter once a year :)
  2. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    I never thought of that...? Probably would still do an oil change...? still thinking :)
    I'm at 16.2K now & have added almost exactly 3.0 qts since the last oil change.
    I'll probably try to get to 18K before I change the oil - & of course send off another sample :)
    I do know that it will use more oil on the interstate than it does around town.
    Its been a while since I took a long trip on the interstate but a while back I calculated I was only getting about 3700mi/qt when driving long distances at ~75mph.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Now at 110k on my 2012 PiP. Oil changed with no noticeable consumption at my usual 10k OCI. Last change was on Valvoline 0w20. This time around, I put in the good stuff, Mobil 1 because it was on sale. I complement it with the cheapest oil filter on Amazon. Falling sharply to 20% EV ratio since DW has the longer commute and can't charge at work.
  4. Mendel Leisk
    41,460
    How much does that save you? Maybe a buck? I just can't see gambling over a trivial savings.
    orenji likes this.
  5. mmmodem
    2,732
    1,703
    Bay Area, CA
    To me, it's not gambling. It's wasting money, otherwise.
  6. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    The Toyota oil filter was designed and tested to handle a 10k mile OCI. Owners have confirmed the filter media won't tear or fold during this interval, nor will it leak around the gasket. Personally, I wouldn't take that bet with the cheapest oil filter on Amazon, especially with a filter that's not rated to 10k.
    #66 BruceInOKC, Oct 10, 2016
    orenji and mmmodem like this.
  7. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    Try using a heavier oil like 5w-20,many have reported benefit.
  8. Former Member 68813
    3,524
    983
    US
    except 5W20 is not much "heavier". 5W30 is more like it and 15W40 would be great.
  9. Mendel Leisk
    41,460
    5W30 is 2nd gen spec'd oil, fwiw.
  10. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I don't understand this survey. What I'd want to know is relationship between oil change interval and mileage at which the engine failed, as well as driving conditions. And you'd need data from at least several hundred cars; anything less is anecdote.
    My 2012 Plug-in will hit 100K in a week and here's the list of repairs it's required:
    1) Nothing
    2) Nothing else
    #70 Rebound, Oct 13, 2016
  11. Former Member 68813
    3,524
    983
    US
    well, don't blame me, blame the people who didn't vote. have you voted BTW?
    over 6000 people saw the thread, but only 79 bothered to vote.
    mmmodem likes this.
  12. Rebound
    3,996
    2,644
    Portland, OR
    Have I voted? Have I voted? It's an election year, of course I'm voting! It's the most important election of our lifetime! Marijuana legalization is finally on the ballot, and you ask if I'm voting?
    I also voted in your poll. 10K and no leaks
    Former Member 68813 and kc410 like this.
  13. orenji
    orenji Senior Member
    5,887
    3,488
    Wow so your nothing never needed replacing? :ROFLMAO:
  14. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Might have missed it,but how many miles when you switched and any results since the switch, or is it too early to tell?
  15. orenji
    5,887
    3,488
    I switched at 50K miles on C and 60K miles on Gen III. Neither car is burning oil, so I am just being proactive.
    mmmodem and Raytheeagle like this.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Even the best laid plans go to waste sometimes though:(. Good move since you reside in a nice temperate climate.
    If it does start to burn a little oil, there are plenty of things you can do to slow the burn;). But at a 5k oil change, it should take a long time.
    orenji likes this.
  17. Rebound
    3,996
    2,644
    Portland, OR
    Maintenance is not a repair. Replacing my tires at their normal replacement time -- around 60,000 miles -- was not a repair. Oil changes, scheduled filter replacements, those are not repairs. I've driven 100,000 miles with no repairs at all. Nothing has broken.
    orenji likes this.
  18. Former Member 68813
    3,524
    983
    US
    OP here.
    For the record, I changed my vote from no consumption to consumption as it started at 75000 miles. 10,000 OCI. Now, it looks like there is association of 10,000 OCI with consumption.
    orenji and m.wynn like this.
  19. ETC(SS)
    7,160
    If there's anything that we've learned recently......it's the fact that there's a yuuuuge difference between voting and participating in a poll.
    I always participate in the former, but very rarely in the latter.
    TIFWIW.....
    Updating my previous answer:
    120,000 miles.
    5,000 mile OCI. (company mandated)
    Zero detectable oil use.
    Moderate to heavy vehicle use (NEVER buy a used work or rental vehicle!)
    In my never to be humbled opinion, many of the people who develop "early onset oil use" do not monitor their oil levels.
    All it takes is ONE service attendant not putting enough oil in the sump to turn a well-running ICE into one that drinks like a Senator and smokes like John Wayne........
    YMMV
    orenji and Samprocat like this.
  20. Former Member 68813
    3,524
    983
    US
    Wrong assessment in regards to myself. You would be hard pressed to find someone maintaining cars more than myself.
