Oil consumption
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by oldasdust, Nov 18, 2015.
  1. Mendel Leisk
    42,339
    Just low pressure, and reports here are usually along the lines of: "started noticing this oil light, and when I checked there was no oil on the dipstick".
    KokomoKid and Prodigyplace like this.
  2. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    That explains very high oil consumption, or blown engines after the red light comes on.
    SM-G930V using PriusChat mobile app
    Mendel Leisk and Prodigyplace like this.
  3. milkman44
    milkman44 Active Member
    591
    386
    Ky
    High oil consumption is already there, that causes the low oil pressure light to come on, Running the car with low oil level causes engine damage.
    Raytheeagle likes this.
  4. KokomoKid
    KokomoKid Member
    115
    82
    Florida and Indiana
    If the car uses a quart of oil in 2000 miles, it's not a big deal, unless you let it run out of oil. You just need to check the oil every few weeks, and add a quart when it gets down to the add mark. Kind of like the 1950 Plymouth I drove while in high school, only it burned a quart in 300 miles.
