Oil consumption
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeanie P, May 3, 2016.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Well you took it to Toyota every time... so wouldn't that make them responsible?
  2. Mendel Leisk
    42,365
    Yes and no. If they're conscientious they would check the oil level prior to the drain, and alert the owner, if they see it's dropped. Especially if it's dropped a lot.
    But are they obligated to do anything more than drain and fill it? Perfect storm, for a car that's consuming oil: dealer changes oil, that's all, and owner rarely if ever checks level.
    #22 Mendel Leisk, Apr 6, 2017
    johnjohnchu likes this.
    52,880
    they are not responsible unless there was a problem while under warranty. it's almost 10 years old.
  4. jim0266
    jim0266 Junior Member
    33
    akron, ohio
    125k on our 2007 Prius. Purchased new, oil changed every 5k, exclusively synthetic oil. Car is burning a good amount of oil these days. Was hoping to go all EV is a few years. My used Leaf is a great town car having replaced my 98 Camry, but need a longer-range EV to go all electric. Feel like I could not sell it privately with this issue and Toyota is nowhere when it comes to EV's. Guess I'll keep adding oil and run the car until it dies.
  5. Mendel Leisk
    42,365
    Can you rough estimate the rate?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Dealer oil change service is a death sentence for your car.
  7. Mendel Leisk
    42,365
    One thing with that: you can get complacent, never check the the oil level. Dealership drains it into a large oil catch gizmo, doesn't see the (reduced) drained volume. So increasing consumption can go unnoticed.
  8. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I feel pretty fortunate. At 142k miles my 2008 is only burning one quart every 3k miles.
  9. JC91006
    16,937
    8,647
    I bought an 05 with 170k miles on it, serviced at the dealer until 150k. Burns very little oil and runs really well.
    My 2008 goes through some oil but I have a leak in the pan gasket. I have to change that out and see if oil is actually burning.
  10. jim0266
    33
    akron, ohio
    I filled to the top dot, ran it 500 miles. The attached image is the oil drop over that time.
  11. Mendel Leisk
    42,365
    Measuring the image on my screen, I get this in mm:
    In second gen Owner's Manual, the distant between the two dimples is said to be 1.6 US quarts. Running a couple of ratio equations from that:
    Your consumption in 500 miles is about 0.35 quart, and extrapolating, a quart would be consumed every 1437 miles.
    Addendum: just to avoid TOTAL geekdom, say a quart every 1500 miles.
    #31 Mendel Leisk, Nov 13, 2018
  12. jim0266
    33
    akron, ohio
    This photo was taken a few weeks before I changed the oil. Based on what I added the last 6 months I would say your estimate of a quart every 1500 miles is spot on.
    Would this be considered excessive for a 07 Prius with 125K miles? Now that we've added a 2nd EV the Prius has become a spare car so it won't be driven more than a few thousand miles a year. Would it be worth trying BG109 on it?
    Raytheeagle likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I use EPR (PN 109) along woth extended life MOA and it works for us.
    I had oil consumption around a quart every 4500 miles and it reduced it down to less than a quart for every 10 k miles.
    But everyone’s results vary. I use it though successfully (y).
    Aaron Vitolins and Merkey like this.
