Oil dipstick reading
Discussion in 'Gen 3 Prius Main Forum' started by StephenJ, Aug 26, 2017.
  1. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Hey guys, how much oil does the dipstick account for? If it's say .25" - .50" below the top dot how much oil is that? Also, when you get the oil changed somewhere does it usually end up right on the top dot?
    BTW it's not my car so I can't just fill it up to see. I'm car shopping. This is specific to a 2011 if it varies from year to year.
    Thanks!
    Stephen
    #1 StephenJ, Aug 26, 2017
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I guess you made it to Virginia Beach :).
    That would be about a 1/3 of a quart.
    Good luck (y),
  3. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    Thanks! How many miles does it typically take the oil to turn from honey color to dirty looking?
    Car has honey colored oil and I'm trying to gauge miles. Looks like it's used about 1/3 or a qt or so.
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    Perhaps they just changed the oil.
    Raytheeagle likes this.
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    That's what usually happens and it was probably filled to that level;).
    You will not be able to gauge oil burn with it sitting on the lot or on a short test drive.
    Good luck and let us know how it works out(y)
  6. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Don't quote me, but I believe I read somewhere that there's a 1.6 quart drop between the high and low marks on the dipstick.
  7. StephenJ
    StephenJ Member
    226
    63
    Birmingham, AL
    Four Touring
    What I'm trying to Guage is if oil starts looking dark at 500 miles then the car drank quite a bit since the oil is still honey and it's 1/3 qt low
  8. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I wouldn't put too much stock in assuming that the dealer filled the oil level to exactly the top mark. Mine notoriously overfills my crankcase with their bulk oil.
  9. BZzap!
    BZzap! Senior Member
    1,607
    878
    When I change my oil I usually put in 4 1/3 quarts to get it on the upper fill limit (top hole). When the oil new it's relatively clear and hard to read. After a 1000 miles or so the oil starts to get honey colored. At oil change time (5k my car) the oil is darker but still very transparent. I choose 5k intervals due to the short trip conditions. My car is a 2012 with slightly less that 50k on the clock.
    ALS and Mendel Leisk like this.
  10. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Same here, with my '14. The Prius is the first car that I have used full synthetic. I could barely see the oil after it was changed. I checked yesterday and it was transparent, but darker honey colored. This is with 7.5k miles since the last oil change. With dino oil, a comparable color would look like oil after 1k miles.
  11. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Can anyone confirm or refute this? It would be good to know. I always just assumed that it was a quart between the two marks.
  12. Mendel Leisk
    42,364
    Yeah it's shown in Maintenance section of Ownner's Manual: 1.6 qt or 1.5 litre. The 2 pips measure 1.5" apart too.
    I believe fill to top mark is 4.5 qt? I go with the metric 4.2 litre. Both those are WITH oil filter change. Without is maybe .2 litre less?
    When measuring the dipstick, if you wait 5 min before reinserting to check, it'll be a lot easier to read. I guess oil tends to be drawn up into the guide tube, and the wait allows it to drain.
    #12 Mendel Leisk, Aug 27, 2017
  13. RRxing
    2,564
    1,842
    NEPA
    Yeah, that's where I saw it... ;)
    Raytheeagle and Mendel Leisk like this.
  14. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Question - If oil is barely registered on the dipstick, how much oil is left in the pan itself?
  15. bisco
    52,878
    one quart
    mikey_t likes this.
  16. mikey_t
    371
    391
    Los Angeles
    Thank you. I checked my oil this morning and there was just the smallest amount on the bottom of the dipstick. I panicked and bought three quarts at Toyota and poured it in, but then it looked way over. Maybe it'll settle properly in the evening?
  17. bisco
    52,878
    not likely.
    but check it in the morning and drain the excess. do not start the car until it is at or below full.
    are you burning a lot of oil? how many miles on her?
    mikey_t likes this.
  18. Mendel Leisk
    42,364
    I've found carefully measured fill of 4.4 qts (specd qty) put the oil level almost 1/4" below top mark. Distance between marks is roughly 1.5 qts, according to Toyota. Distance between marks is also roughly 1.5".
    You should be able to extrapolate from the above.
    mikey_t likes this.
  19. bisco
    52,878
    the problem is determining the oil level on the stick
  20. mikey_t
    371
    391
    Los Angeles
    Around 160,000. Currently burning oil like crazy, but I've been in the mountains the last seven weeks so lots of uphill driving which pushes the engine. I topped off the oil when I got here which put it around the halfway mark between the dots.
