Oil dipstick reading
Discussion in 'Gen 3 Prius Main Forum' started by StephenJ, Aug 26, 2017.
  1. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Unfortunately I don't think I have a way of draining it where I'm at unless I can find something to use as a siphon.
    52,878
    up to about 3/8" over, i'd be comfortable driving to an auto parts store
  3. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    If it's not over the full mark a lot (say a half inch or more) I wouldn't be concerned about draining any out. When I do my oil changes, I always put in the full 5 quarts (a half quart more than specified) and it reads maybe a quarter inch above full. It doesn't cause a problem. Especially since yours is going to use it down fairly quickly.
  4. mikey_t
    371
    391
    Los Angeles
    It's way over the full mark. I'm a bit baffled honestly. When I checked this morning, there was just a drop of oil on the dipstick. So I would have thought that adding three quarts wouldn't have put it so over the top.
  5. mikey_t
    371
    391
    Los Angeles
    I've acquired a siphon but it's just too large to fit down the dipstick tube. Any suggestions?
  6. Mendel Leisk
    42,364
    What I've done a few times is loosen the drain bolt till it's almost off, then hold it in place but slightly cant it slightly, get a trickle going. I've drained off up to a pint thus, but it is stressful, and by a pint my arm is starting to shake.
    Another trick would be to completely remove the drain bolt, let it rip. Into a clean drain pan. Reinstall the drain bolt and pour the oil back in, minus the overfill.
    Hindsight is 20/20, but it is SO much easier to add oil than to remove it.
    #26 Mendel Leisk, Jul 28, 2020
    ASRDogman and mikey_t like this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I have a siphon pump with a straw like end that’s 5 ft long and successfully extracted engine oil thru the dipstick if you will eventually want one, they do exist.
    #27 Grit, Jul 28, 2020
  8. mikey_t
    371
    391
    Los Angeles
    Can I do that without lifting the car?
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Depends on how skinny you are;).
    If your oil change door is no longer attached, it might be possible:).
    Only one way to find out (y).
  10. mikey_t
    371
    391
    Los Angeles
    I found some thinner tube in the garage that fit snugly into the siphon tube. I'll give that whirl in the morning. If nothing else, I can use just that and hope not to end up gargling motor oil.
    Prodigyplace likes this.
  11. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    You can jack up the passenger side, place the jack under the back bolt of the control arm.
    And put a jack stand under the frame. Then you can get in through the front. Fairly easy.
    Mendel's idea of a clean pan and just let it drain is probably the easiest and less stressful.
    :)(y)
    mikey_t and jerrymildred like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I'm pretty strongly inclined to agree with @ASRDogman. Another way is to find a curb you can drive up on. I siphoned oil out of my motorcycle once. I'll never do that again!!!!!! I then rode from Yellowstone NP to Denver spitting out from under a full coverage helmet in a vain attempt to get the taste out of my mouth. After that, I'll go anything to avoid getting motor oil in my mouth again.
    mikey_t and Prodigyplace like this.
  13. ASRDogman
    8,067
    4,089
    They do make suction guns.... I have one! I watched someone sucking on a hose to pull gas out
    of his car for his mower... I learned NEVER to do that!!!
  14. Mendel Leisk
    42,364
    I don't think it's possible, and raising definitely the way to go. Ramps would be shortest/quickest route if you're not set up for this.
    mikey_t likes this.
  15. Mendel Leisk
    42,364
    There are fluid transfer syringes (roughly one pint capacity) you can push a long skinny tube onto.
    mikey_t likes this.
  16. jerrymildred
    11,517
    14,171
    Tampa, FL
    Well, sadly, I was a dirt poor college kid on a ride from California, up through British Columbia, down through Yellowstone, to Colorado on my old Kawasaki 350 and didn't have a suction pump with me. :oops:
    But, at least I didn't do like some of the "street entertainers" I saw in Honduras who do a flame-throwing act in the middle of the street using mouths-full of diesel fuel to solicit a few coins. :eek:
    ASRDogman likes this.
  17. ASRDogman
    8,067
    4,089
    :eek::confused:
    jerrymildred likes this.
  18. bettergolf
    495
    370
    Sanford NC
    I have a cheap siphon pump I bought off amazon a few years back to "change" the cvt fluid in a Jeep Patriot. Since like Toyota, Jeep says it's "lifetime" fluid, they didn't even put a drain plug on the transmission pan. I siphoned (pumped) out as much as I could and refilled the same amount back in through the filler tube, then did that again a few weeks later, Not a full exchange, but much better than nothing!.
    The pump looks something like a bicycle pump but smaller and with 2 hoses. Probably less than $20, I don't remember.
  19. mikey_t
    371
    391
    Los Angeles
    That probably would have been much more efficient. Took me about an hour and a half using the siphon my friend brought me. I had to cut the original tube in half to get less air and the hand pump was the squeeze kind, it slightly leaked so it got a bit messy. But all's good now and I won't make that mistake again!
    jerrymildred and Mendel Leisk like this.
