Oil dipstick reading?
Discussion in 'Gen 2 Prius Technical Discussion' started by Christopher Kim, Oct 23, 2023.
  1. Christopher Kim
    Christopher Kim Junior Member
    31
    North Carolina
    Hey guys. So when I go to check my oil, I noticed that one side of the dipstick is full to where it needs to be but when I turn it around it’s only half way. I’ve already let the car sit, overnight etc and I get the same readings. Anybody got a better answer on which side is accurate??
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    I personally use the flipped over side as my full reading better to be a tad low than overfilled
    ColoradoBoo likes this.
  3. ColoradoBoo
    ColoradoBoo Senior Member
    1,338
    961
    Monument, Colorado USA
    If you check the oil first thing in the morning, it will show much more than normal because the oil has had all night to settle.
    The best way to check oil is to run the vehicle for a while than turn it off and wait about a minute or two. (5 minutes with diesels and those with turbos.)
    I've never seen one side different than the other...how is this possible?
  4. Tombukt2
    13,809
    2,504
    Durham NC
    Both the NZ and ZZ do this . I'm not sure why. But the best reference you can get is to fill the oil on the oil change with the proper amount you're supposed to put in the car with the new filter which is what 4.7 q or some nonsense then start the car fill the filter light goes out all this good stuff your car is probably still warm from where you warmed it to change the oil then turn the car off let it sit 5 minutes just to be doing so then check the oil then look at both sides of the stick and see what you're seeing and reference that as being full and then use that parameter from then on You can have pretty much no leaks the car was just filled with the exact amount of oil required by the manufacturer with a new filter you've run the car filled the filter so on and so forth and so now you should be sitting at your reference full anytime you check your oil you're looking for this level whatever side of the stick you're looking at and try to stick to that.
  5. Christopher Kim
    31
    North Carolina
    The flipped side meaning the side facing the bumper and not the engine correct??
  6. Christopher Kim
    31
    North Carolina
    I’ve done this and got the same readings and I’m not sure but I’ve read other people have had this issue as well
  7. Christopher Kim
    31
    North Carolina
    Yes I will do this on my next oil change but was just wondering in terms of now if I need to cap off or not
  8. Tombukt2
    13,809
    2,504
    Durham NC
    If you're showing full on the one side don't cap it off or don't top it off It's completely unnecessary You are well within the operating range of the engine oil requirements so you should be good to go.
  9. Christopher Kim
    31
    North Carolina
    Here’s what I’m referring too
  10. Christopher Kim
    31
    North Carolina
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I see the identical thing on all my Gen 2s that you're seeing on yours. I always use the lower reading. I fully believe the higher reading is just oil that is wiping off the dipstick tube (or other surface), onto the dipstick. The lower one matches well with how much oil is added during an oil and filter change.
    If you clean it and re-dip several times, you'll see that the lower is more consistent.
  12. Christopher Kim
    31
    North Carolina
    I’ve cleaned and re-dipped multiple times and still get the same reading on both sides.
    When you do an oil change, how does your dipstick read right after? Are both sides even or do you still get these readings?
  13. Christopher Kim
    31
    North Carolina
  14. Christopher Kim
    31
    North Carolina
    because I’m getting different answers, one end tells me to follow the high side and the other the low side
  15. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    This picture may explain how you can get different apparent oil levels on different sides of the dipstick, when the dipstick is in the oil at an angle. Yours must be at a very shallow angle to read that differently on either side.
    Take the lower reading of the two sides as the true oil level.
    #14 xliderider, Oct 23, 2023
  16. Christopher Kim
    31
    North Carolina
    Ended up topping from the lower side and now it’s even! Thanks man
  17. ColoradoBoo
    1,338
    961
    Looking at those readings, I'd call it good....better to have just a tad too low than to over-fill....imho. There's about a half-a-quart of wiggle-room that doesn't hurt anything...thus the reason for the 2 dots. I'll only add more oil if both were down near the bottom.
    And kudos on that clean-looking oil! :)
  18. Christopher Kim
    31
    North Carolina
    I actually ended up topping it off due to a post on here and now they are even from both sides! But thanks, this is actually at my 5000 interval where I usually do a oil change but I’m gonna push for another 1000
