  1. fkoali
    fkoali New Member
    Jordan
    Dear all
    I have prius 2007 , 230Km , i notic that the car eat a bout 1k oil each 5000 km , please if any one has an idea a bout this ?
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    What exactly is "1k" of oil ?
    If you mean one liter, then that is to be expected.
    Cars use more oil as the miles pile up.
    See other threads on here about oil usage.
    fkoali likes this.
  3. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    You must mean 230 thousand kilometers? And about liter per 5000km? That doesn’t sound so big that you would repair or rebuild the engine. What kind of oil are you using? Different oil might help? You can check that the PCV-valve is working fine.
    fkoali likes this.
  4. fkoali
    fkoali New Member
    Jordan
    Yes i ment 1 kilo or 1 liter , i used 10w 40 , they told me it might be a problem with motor ring , do you think this is true ?
  5. Mendel Leisk
    38,705
    I'm thinking "motor ring" is what's commonly called "piston ring".
    One liter of oil in 5000 kms, with 230,000 kms on the car, is "not bad". That actually just about the same situation as an 06 Civic Hybrid in our family, and the same amount of oil consumption, lol.
    It might be due to gunk/carbon building up on the rings, and you could try gas additives, to try to loosen/clear those deposits. I'm not sure they're that effective though. Doing anything more invasive, say rebuilding or replacing the engine, would be overkill in my opinion.
    Again, it's not to serious a consumption level, and considering the mileage: I would just monitor the oil level relatively frequently, add oil as required.
    fkoali likes this.
  6. bisco
    49,433
    welcome!
    do you have access to salvage engines?
    fkoali likes this.
  7. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Are any of those 5000 km driven on the Koala Autobahn, or at 115 kph and greater. If so you could try slowing down and see if the oil usage changes at all.
    fkoali likes this.
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    1l/5000km is not even close to a lot, it translates to about 1qt/3000 miles. That rate of consumption is well within normal and not a reason for investigation or concern.
    fkoali and Mendel Leisk like this.
  9. fkoali
    fkoali New Member
    Jordan
    What do you mean by salvage engine ?
  10. Mendel Leisk
    38,705
    Replace your engine, with another used engine, say from a crashed-and-beyond-repair vehicle with lower miles.
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    only if the oil eating gets worse.
    fkoali and SFO like this.
  12. 05PreeUs
    1,097
    563
    MSP
    Like 10 times worse ;)
