Oil filter leak - please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mfavro, Nov 28, 2012.
  1. mfavro
    mfavro New Member
    bellingham, wa
    I have a 2010 prius I bought in March and just performed my first oil change. When I tried to remove the filter it was really "cranked on" but with the right filter cap tool I finally got it off with a ton of effort. Put in the new filter incert, new rubber o-ring and put the oil filter back in, tightened it snug, not to tight. Had a small oil leak from the filter. Went out got a new rubber o-ring (assuming it was the issue), put it all back together and now it's still leaking from the oil filter. I'm totally at a loss for what it could be? Any one had this issue? Anyone have a pic of the exact placement of where the o-ring goes? I looked and it doesn't look like the filter housing is cracked, but I guess it's a possibility? Any help would be greatly appreciated!
  2. gliderman
    gliderman Active Member
    751
    225
    Buy another filter housing. I looked into it once and you can get it online for about $30 plus shipping. Dealer may be considerably higher. I dont know.
    Montgomery and TsKarma like this.
  3. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    did you put the oil ring in the right groove?? You may have not noticed where it was at when you removed it? I think it would be the outer groove away from the engine, it seats in the double ridge grove. http://john1701a.com/prius/documents/Prius_Maintenance_Changing-Oil.pdf
    Satcatcher, Montgomery and TsKarma like this.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There could be a fracture in the housing that isn't noticeable to the eye. Doubt it is the o-ring. Guess I would order a new housing from a place like parts.com.
    TsKarma and GSW like this.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I second GaryD1. I would make sure you had the O-ring in the correct groove. If you are absolutely sure that you replaced the O-ring in the correct groove then I would check in to the new filter housing.
    I have had my filter so tight from the dealership that I had to use a breaker bar. One of the many reasons I do my own maintenance now. I have never had a leak from the filter housing.
    TsKarma likes this.
  6. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    Solely from a cost standpoint, shouldn't he try just a new filter, first? My thought is that maybe the filter isn't fitting quite right (for whatever reason).
    Mike
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The filter cap is nylon, so there's probably a crack. I would replace it asap before you destroy the engine.
    Montgomery likes this.
  8. mfavro
    mfavro New Member
    bellingham, wa
    Thanks everyone for the recommendation. I'm going to try to replace the cap / filter / o-ring all with new parts and hopefully that fixes it. I found the filter cap on e-bay for $32 and $8 for the filter so hopefully only a $40 fix. Thanks for your help!
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Is there only one o-ring on the cap ?
    I haven't done an oil change myself, but I saw pictures, on Ebay, of the paper filter for sale with two o-rings, a large one and a smaller one.
  10. The Critic
    3,193
    2,333
    CA
    One large oring only. Torque to 18 ft-lbs, which is basically as tight as you can get it by hand with the filter cup attached.
    iPhone ?
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    In this case, just one as mentioned above. Our Kia van however had two; a large one like the prius and then a smaller one that attached to the rod that went all the way through the filter element.
  12. Mendel Leisk
    42,223
    When you're tightening it will spin relatively easily until the the o-ring gets back into the cylindrical cavity. Then resistance goes up, but you've still got aways to go, till the cap bottoms out. As long as the o-ring is well into that cavity I believe it will be tight. As long as the cap is not cracked somehow.
    Here's a pic of where the oil filter ring (item *2) should be:
    There's a picture on the replacement filter box as well, I think. It should be in a groove, just beyond the thread area.
    Danny3xd () and TsKarma like this.
  13. JasonB
    JasonB Junior Member
    23
    Fort Worth
    The small washer isn't an o-ring, it's the crush washer for the oil pan plug.
  14. Danny3xd ()
    Danny3xd () Member
    85
    38
    Connecticut
    Really old thread but wanted to double check ring placement. Thanks ML! Just what I was looking for.
    Still having issues with removing oil filter cap. Way to hard.
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Save your money and invest in changing the whole darn thing out:
    Part# 156090T060- Bracket for oil filter- $79.80
    Part# 9090404006- Union Bolt- #11.76
    Part# 9672324020- O- rings- $2.46
    Spin Oil Filters:
    Fram- PH4386
    Fram Extra- PH4967
    Toyota Filter- 90915-YZZF2
    All legit parts from your local Toyota dealer. Took me less that 15 minutes to change out.
    Go to: The 2016+ Toyota 2zr Engine oil filter conversion - Armstrong Family Blog
    For step by step directions with color photos!!
    Its worth it!!
  16. Mendel Leisk
    42,223
    N'mind, read the link, understand.
  17. Mendel Leisk
    42,223
    You put it on the last time?
    Really liberally oil the O-ring, both before install and after. Torque to 18 foot/pounds. When removing, helps to have a long-handled ratchet wrench. You can count on it requiring a wrench most of the way out, at least until the O-ring emerges.
    #17 Mendel Leisk, Jun 10, 2019
    Robert Holt and Danny3xd () like this.
  18. CR94
    CR94 Senior Member
    2,812
    1,235
    Northwestern S.C.
    I agree mostly. If it wasn't overtightened, you should not need a long handle. It's easy!
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thought the toyota paper cartridges are only $4-$5 a piece, and that was the only thing to buy for oil change which kept cost down. Spending money on the spin on kit, and with spin-on filters much more expensive than paper cartridges, youre not going to save any money even after the kit is installed.
    And then your ecological footprint will be larger than before with the metal can.
    Robert Holt, kithmo, jb in NE and 2 others like this.
  20. Danny3xd ()
    Danny3xd () Member
    85
    38
    Connecticut
    Did that help with the "No mater what I do this Freakin' thing won't come off easily?" thing Montgomery? Out of around 6 or 8 oil changes, it came off like it should once! Once, I tell ya. ONCE! snork. I would invest if asured the 20 minute job every other month didn't turn into an ordeal. (I drive a lot)
