Oil filter leak - please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mfavro, Nov 28, 2012.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    You got the one that's Made in Japan. Maybe they don't import the one from Japan, any more, since they make it here in the USA now.
    Montgomery and Mendel Leisk like this.
  2. Mendel Leisk
    42,361
    Differences I can see:
    Georgina Rudkus likes this.
  3. Mendel Leisk
    42,361
    For the retrofit market I guess. Obvious the made in Japan newer Prius come across with that bracket installed.
  4. Mendel Leisk
    42,361
    Here's the stock filter on ours, appears to be some sorta doohickey in that vicinity. Was a thing for a while, then they thought better of it?
  5. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Could be that the supplier has only one high pressure injection mold in Japan and couldn't spare to send it here to the US.
    Thus, they revised the new mold made here in the US to use less aluminum or to make it simpler. A little saving in metal for each unit multiplied by over 100k units add up to a sizeable savings in cost.
  6. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    My uneducated guess is that the original mold has its own patent, thus, any copy has to have something different, hence, no violation of original patented mold. Just a guess.
  7. Mendel Leisk
    42,361
    So I can exhale? :whistle:
    Raytheeagle likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Do you ever do that:p.
    mjoo and Mendel Leisk like this.
  9. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    there HAS to be a reason for this little 'drops'; they don't leave the material there for nothing or for pure convenience /
  10. Montgomery
    2,254
    2,244
    Orange County, CA
    It was put there so it would wind up being in a blog somewhere, causing deep comtemplation and discussion, ever reminding us of how the human species must always have an answer......................... (y)
  11. Mendel Leisk
    42,361
    It worked. I was gonna keep quiet, but here's a flatbed scan I did, then brought it into AutoCad, looking for clues:
    Gave up, when back to my crop circle studies...
  12. Montgomery
    2,254
    2,244
    Orange County, CA
    LoL, love it Mendel, Love it!
  13. Montgomery
    2,254
    2,244
    Orange County, CA
    When you think about it, that point at the end helps you position it when installing it.
  14. Montgomery
    2,254
    2,244
    Orange County, CA
    And, I have to add, it's so much easier to change the filter. It really is.
  15. Mendel Leisk
    42,361
    Yeah: "this point down". My favourite hunch is it's to concentrate the draining oil to one point?
    I'm sitting on my hands till the spring oil change, it's tough.
  16. Montgomery
    2,254
    2,244
    Orange County, CA
    Like I had mentioned earlier, I have been changing my own oil since 1974. The simple easy trick with spin on filters is to put oil on the rubber oil ring and hand tighten it. I always tightened it till it was fairly hard to turn. Once you start the car, the pressure sucks against the canister, sealing it. Yes, sometimes when I went to change it, it was sticky, but I was always able to losen it with the "O" ring canister remover. The plastic cover that comes with the Prius expands due to heat and literally "glues" itself to the metal around it. If the cover was metal, I bet it wouldn't get stuck.
  17. Mendel Leisk
    42,361
    First time buying a spin-on filter for the Prius, I notice the end with gasket has a clear-plastic seal, and rubber ring under has a light coat of some clear grease. I'll add a little oil for good measure (Repair Manual instruction says to do this). IIRC the oil filter box also says to put oil on.
    I'll just torque to spec'd 13 foot pounds. I think that's slightly more than you could do by hand, with clean hands and filter.
    I was getting a spin-on filter for our son's CX-5 at same time (Open Road Toyota and Mazda are side by side in Pomo), and it had the same clear plastic over cover, light lube on the gasket. Very similar in appearance.
    Addendum: the other tightening spec is 3/4 turn beyond first contact, pretty much industry standard.
    #117 Mendel Leisk, Jan 13, 2020
  18. Fmoua916
    Fmoua916 New Member
    Sacramento
    All you have to do is put on the oil cap and attach on the ratchet and hold it whole hitting it 2-3 times with a rubber mallet and it will help loosen it and then you can loosen the rest. Not that hard at all guys come on here haha
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I got poo pooed on for saying use your foot to push the wrench. If your method doesn’t get the same treatment then i will file a complaint.
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    And then put the pin in place so filter doesn’t unscrew it loose. But some says the pin is there for ornamental purpose.
