Oil Filter Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RRxing, May 25, 2012.
  1. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    I just passed 40K miles on my car (averaging ~14K/year.) I plan on performing two oil changes a year (using Toyota 0w-20) - one in May, the other in early November. Here's my question - If I use a TRD oil filter in May, would it be okay to skip the filter change in November and just replace the oil? In other words, does anyone see a problem in letting the TRD oil filter go to 14K miles (instead of the recommended 10K interval)?
    Thanks in advance...
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    No issues. What is unusual is those that care enough to plan the changes, select the oil, and post the questions are usually those that go through on changing the filter. However, 14k vs 10k on the filter is not risking the engine.
  3. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Are you going to just drain your oil via the drain plug, or will you also drain the oil in the filter housing? The little bit of oil in the housing would bother the OCD me.
    The TRD filters are pretty robust (I use them), and would be up to your extended interval, in my opinion, since the Prius isn't "hard" on engine oil. I'm not sure you wouldn't be better off just using plain Toyota filter elements and changing them out each interval, though.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    I don't see a major problem, 14K miles in a Gen III is comparable in engine wear to 10K miles in a Corolla. On the other hand, it is worth the piece of mind for me to change the filter every time I change the oil.
  5. tv4fish
    tv4fish Member
    202
    46
    Gotta agree with seilerts (again :)) Why risk the possibility of dislodging some crap that might have been caught in the filter -- plus "contaminating" the new oil with the old oil?
  6. DonVentura
    DonVentura SoCal Prius Driver
    78
    Ventura, CA
    I agree that it wont hurt it one little bit, but the used oil in the filter housing would bug me. Since I would need to pull it off I would look at the filter (have another one hand) and decide for myself depending on what it looks like.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    My mechanical engineering brother-in-law's opinion on this subject is that if, in a hypothetical situation, he had to choose between changing the oil or the filter, he would change the filter since this is what traps the particles in the oil. Of course his first choice would be to always change the filter with the oil change.
  8. Mendel Leisk
    42,380
    Honda maintenance schedules indicate to only change the oil filter at alternate oil changes. Try getting the dealerships to stick to that is another story... Anyway,
    One have-your-cake-and-eat-it-too method: at an oil change without a filter change, remove the filter anyway, drain and re-install it. That way you get the cup or so of used oil that otherwise remain in the filter.
  9. RRxing
    2,564
    1,842
    NEPA
    Thanks to all who responded so far - good points, all...
    I didn't think about the residual oil in the filter, but now that it's been mentioned, it's gonna bug me as well, so I'll do the oil and filter swaps each time.
    Thanks again.
  10. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    SMART MOVE ! When you consider the very small cost, even for the quality TRD synthetic filter, it's really not very smart, in fact STUPID
    to not change the filter at the same time s changing the oil.
    Most of the cheapskates who don't piss away more money on their
    booze !
