Oil filter tool stuck to oil filter!!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JDB, May 30, 2015.
  1. JDB
    JDB Junior Member
    24
    Did my own 30k oil filter change today after taking it to the dealership for 10k and 20k. What do you know, they over torqued the crap out of the filter that I had to use my 1/2" breaker bar and all my strength to remove it. After all of that somehow the oil filter tool (the typical one suggested by everyone here) ended up getting stuck to the oil filter cap. It was at a slight angle so it must have shifted as I was trying to loosen it with the breaker bar. Well, spent the next hour trying to separate them with no luck. Didn't want to damage the filter housing, and since the tool was stuck on there good just decided to put it back on with the tool attached. Anyone have this same experience? Any concerns about leaving it on, other than it randomly falling off one day?
    Hopefully I'll still find the tool attached next time I change my oil, maybe pick up an extra oil filter cap and tool just in case. Btw I changed it myself at 5k before doing the free changes at dealership. Another reason I won't let them touch my car again...
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Mine got stuck a few years back. It held on so well, I just left it. No harm from doing that. It was annoying at first though, since I really wanted to find a way to get it off. It stayed put.
  3. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I experienced same issue, left it on drove for 10,000 miles till next oil change and it was still on, then had it removed from workshop and never overtorqued it.
  4. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Try lightly tapping it with a hammer to straighten it out on the filter, like you were seating it further on. That will sometimes knock it loose without damaging the new filter.
    Bill the Engineer
    qdllc likes this.
  5. Former Member 68813
    3,524
    983
    US
    LOL, welcome to the club.
  6. Mendel Leisk
    42,306
    I've not had that problem. But then again, nobody else has been near the filter since it left the factory.
    I'd suggest to take a piece of flat iron, say 1/8"x1" by 12" or so long. Lay it against the filter housing touching the stuck filter socket, and give it taps with a hammer. Alternate locations as much as possible. That's gotta get it loose.
    One of my older oil filter sockets (sized for larger filter), has an opening in the socket's dome, you can slip a screw driver in and pry.
    Not helping, I know, just trivia:
    Steph1972 likes this.
  7. Bill the Engineer
    1,048
    2,278
    467
    Oooo! I see a new use for my Sawz-all!
    Bill the Engineer
    Okinawa likes this.
  8. Mendel Leisk
    42,306
    I'd be curious to know, if/when you get the filter socket off: what's the inside face-to-face dimension on it. I'm using a filter socket that I've measured semi-carefully with an inside caliper, get 64.5 mm for that dimension.
    If, for example, yours measures around 65.0 mm, I'm thinking: the looser the fit the more it'll be inclined to jam.
    (Using a digital caliper with dead battery, so just relying on the somewhat rough scale on the caliper. Been meaning to get a decent old-school caliper, but they're kinda hard to come by, and pricier.)
  9. Mendel Leisk
    42,306
    Another thought: did you try putting something like a 6" extension on the socket, then rock the socket back and forth. Maybe couple this with taps from a hammer.
  10. qdllc
    qdllc Senior Member
    1,377
    400
    This. Been there several times. Try to tap it in different directions to "wiggle" it off the part.
  11. A617
    A617 Member
    213
    95
    OKC, OK
    I got a 22mm that was a too tight for the bolt on oil filter tool and pressure fit it on, now when im done just take a small hammer and tap the socket on the left and right of the socket and it pops right out.
  12. Siward
    Siward Active Member
    314
    128
    Toronto
    My oil filter tool got stuck on my first Prius DIY oil change. I simply:
    1) Put the filter housing and tool back on the car
    2) Tighten the filter housing to the point it doesn't move much
    3) Turn/hit your ratchet with the filter tool attached by the socket mostly counterclockwise (but possibly clockwise) until the filter tool losens.
  13. Mendel Leisk
    42,306
    For anyone having it stick on, I'd be really curious to know what the inside face-to-face of the filter socket is.
    I've never had this issue, either taking it off or reinstalling. Rock it a little, off it come it comes. When reinstalling I torque to 18 lb/ft, give the extension I'm using a bit of a wiggle, it's off.
    The inside dim (center of face to center of face) on my (Honda) socket is 64.5 mm.
  14. frodoz737
    frodoz737 Top Wrench
    4,797
    2,560
    33
    I guarantee you those "idiot monkeys" at -iffy Lube everyone talks so bad about don't have this problem. :whistle:
  15. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Watch out, the filter housing is plastic. I cracked and broke my second oil filter wrench trying to loosen it. Then I broke the filter housing after more concerted effort to loosen it. $67 to Toyota for a new filter. Yeah, no one is going to change my oil but me from now on.
    And you know what? Freaking things are still stuck together! I should've just left it on as you did. They're sitting next to my tool box. I'm NOT going to let this filter defeat me. I will figure out how to separate them one of these day even though both items are broken and unusable.
  16. daspi
    daspi Junior Member
    17
    I can't get my filter out. Stuck so tight I got so mad. What idiots tighten these things like that? I used to just hand tighten regular oil filters an they never came loose. This one is so tight that I can not get it out with 3/4 ratchet attached to the proper filter tool that grips the whole filter cap. So what is next? Used even my foot and kicked at the thing. Nothing. Will this plastic cap just break off and part will be still stuck in the base if too much force is applied? What then? I am nervous to apply more force with extensions. Thoughts?
  17. mmmodem
    2,732
    1,703
    Bay Area, CA
    It's really all plastic. I needed a few good kicks with an extension to get it off. If you break it, then you break it, like I did. It's plastic and can be easily pried off.
  18. Mendel Leisk
    42,306
    I'd strongly suspect this is due to "pros" spinning them on with something like a cordless torque wrench at full power. I've always hand torqued to 18 ft/lb, and taking it off just takes a little oomph to get it moving, but no problem.
  19. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    I guess I should make a video on how to remove your stuck oil filter cap lol... Mine get stuck all the time when I remove the filter housing, but when I put it back on tight, and then wiggle the filter cap, it comes off... Not a big deal really...
  20. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Take the handle of your 3/8" ratchet and hit each side of the tool in the direction to get it off (away from the front). It doesn't take much, but you will have to work it for a little while. Mine sticks all the time. If you have a thin steel one (mine is aluminum and thick walled), use a slot screwdriver and hit it. DO NOT use a lot of force, just gentle taps from side to side and it WILL come loose.
    Once again, the filter housing WILL NOT unscrew by itself. It's held by the "O" ring friction and the "O" ring is the only seal. The filter housing doesn't even have to bottom in the engine to work properly, though I suspect the filter is designed to "seat" when it does bottom. Anyway, you don't have to torque it on there. Hand "gentle" tight is good enough.
