Oil filter-trap for air compressor?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by StephenFromCT, Aug 24, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    TPMS is to let you know one or more tires has lower than the set pressure.
    I picked up a screw and over tire it leaks, the light came on. It would be nice if it told you which one! :)
    But I have a tire gauge. It was the right rear so I have to remove it to plug it. Walfart wouldn't patch it
    because it's on the outer tread.
    5000 miles later, it's still fine.
    I check the pressures every 2 or 3 weeks so I would have caught it. And the car was starting to handle
    funny so I knew there was a low tire before the light came on.
  2. Mendel Leisk
    42,389
    FWIW, Mazda has similar sensor, but they self-initialize. If you put snow tires with new (Mazda) sensors on the car, as long as you drive something like 5 minutes above some threshold speed, the car figures it out. And I've priced them, in CDN dollars: $30 bucks apiece for extra sensors.
    (Our son as a CX5, we were looking into snow tires.)
    It's not uncommon for a flat to happen in about a minute: pick a bolt for example.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    VW had a setup that used the ABS wheel speed sensors to determine if one wheel was rotating at a different speed, which would indicate a potential air loss. No TPMS sensors in the wheels, but everytime I rotated the tires or put on the snow tires, it would trigger an alert. Had to go into the glovebox to reset the logic for the new tire/wheel setup.
    I would pass on that and take the spousal unit out for a dinner or two with the savings.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Just put a black tape over the tpms light before inspections.
  5. Salamander_King
    Salamander_King Senior Member
    11,026
    8,988
    New England
    I think there is a hack to disable the light if you jump two pins in the TPMS ECU. At least for Gen2 and Gen3 the hack worked. Not sure for Gen4.
    avongil likes this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Could also be low battery on one of the tpms sensors or issue with one or more of the sensors.
    There was a fella at our meet ups with tpms light on, we plugged techstream to his vehicle, 2 tires and its r pressure weren’t registering w/the tpms system.
    #46 Grit, Aug 27, 2019
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What’s weird is that the tire pressure measured with my racing psi reader & jnc jumper back air compressor gauge reads nearly identical. But tech stream has a +/- 2-3lbs difference from the both.
    #47 Grit, Aug 27, 2019
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Did you have to get the tires rebalanced with the screw on sensors for each tire? I red reviews saying it increased their tire ambient noise level and it went away after balancing. I’m thinking of low rolling resistance tires being light weight, these sensor could work against the add on weight on the lrr tires.
  9. Mendel Leisk
    42,389
    I've got 3 stick gauges and a cheap digital, One of the sticks more-or-less agrees with with the digital, the other two sticks vary, 2~3 pounds. I wonder if somewhere like Costco tire center (or other) could test your gauge(s) for you?
  10. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    No. All they would do is compare them to their gage, which may not be accurate. You would need a lab with a calibration standard to check your gage.
  11. Salamander_King
    11,026
    8,988
    New England
    I never did rebalance my tires after installing external sensors. I don't think I noticed much difference in noize level before and after. Yeah, those sensors are big and ugly but do a far better job than OEM internal sensors. My external sensors read very close to the value from several manual tire pressure gauges as well as internal sensor value read through OBD. FWIW, I used 4 different brands of manual gauges and they all came close within +/- 1psi. The internal sensors readings were 0.9 to 1.4 psi higher than the external sensor (or manual gauges).
    #51 Salamander_King, Aug 27, 2019
    Robert Holt and Grit like this.
  12. avongil
    avongil Member
    67
    56
    Easton, PA
    Thanks! Im going to wire a switch in.
    Salamander_King likes this.
  13. Salamander_King
    11,026
    8,988
    New England
    This thread and diagram on comment #1 may help. The thread is about Gen2, but comment #1 diagram is for Gen3.
    Gen 2 TPMS disable | PriusChat
    I never used the trick on my Gen3. I had snow on the same rim as summer with TPMS. I have separate snow on own rims now for PRIME, but the TPMS light is so far right side of the dash, it does not bother me at all.
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    So does everybody else.
    The TPMS is NOT part of the tire itself.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sure. We know by now that anything that you don't agree with is "nonsense".
    Using your logic, the oil pressure light and engine temperature lights are "nonsense" too.
    IF.....you ever had a slow leak in a tire which culminated in a complete tread failure.......which takes out the fender, wiring and suspension components along with it......and maybe puts you in the hospital or worse, maybe you would have a different perspective.
  16. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I clarified the statement a few posts later, in response to a similar question.
  17. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Neither of those are parameters I can measure with a gage in my hand. I prefer an actual indicator of the parameter for both of these, not just the idiot light.
    My issue with TPMS is not that is an ineffective technology, but that (1) it is mandated to be installed; whether I want it or not, I'm paying for it, (2) there are much less expensive ways to implement it (ABS speed sensors already measure wheel rotation and a few lines of code can make a tire "pressure" warning system).
    I have had a number of flat tires in my lifetime, all due to foreign object penetrating the tread of the tire. None of these have resulted in a blowout, and none of the wheels were equipped with TPMS. You can hear and feel a tire going flat, and a cursory visual inspection can quickly identify a significantly (i.e. 10 lbs down) tire. Apparently looking at tires, and measuring the pressure on a regular interval, is becoming a lost skill.
    #57 jb in NE, Aug 28, 2019
  18. Mendel Leisk
    42,389
    Some times si, sometimes no. It can happen fast.
  19. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    If it happens very fast, the TPMS doesn't provide any useful information - "Hey, that loud noise you just heard and the swerve was due to a flat tire..."
  20. Mendel Leisk
    42,389
    I've had scenarios, everything fine at the outset, got to destination, get out, see one tire's very flat. No explosion, no swerve.
    Ever notice how you're ALWAYS right? I'm gonna say goodby to the eye for a while. :rolleyes:
