Oil FIlter Type on 2022
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by FRCornelis, Jun 3, 2022.
  1. Doug McC
    Doug McC Active Member
    955
    351
    Midwest
    2022 Prius
    Finally got everything together and did the oil change yesterday. I had to buy almost all of the tools I needed (long story as to why). I built a set of ramps to make sure I had enough clearance, 3 step type, with spacing of 14" which actually turned out to be too much. Made them out of 2x8's, which was a bit narrow ((but the 2x10's available at the local Menards (the "Walmart" of the home centers!) were split and really warped)). The total length was 4 feet, and the lowest section actually prevented putting jack stands under the pinch welds at the lifting points if I drove up on the highest level. Turned out, all I really needed was one sort 2x (a lift of 1.5") for the small jack I used (Pittsburgh Automotive 1.5 ton Aluminum Low Profile Rapid Pump racing jack Item # 64545 at Habor Freight). jerrymildred's or Mendel Leisk's designs would be much better if one wanted ramps.
    The Filter End Wrench I bought that fit the Toyota filter 90915-YZZN1 wouldn't grab the factory installed filter # 909915-10003 tight enough to get it off. The factory installed filter was on pretty tight so I ended up using a Carlyle Tools Filter Wrench #77-3324 and there was plenty of room for it (it is a metal strap type) and made the job a whole lot easier. I wouldn't waste money or time on an end wrench.
    I put 4 quarts back in and checked the stick, then added slightly less than 4 ounces which it brought it up to the top mark on the stick. Once I ran the engine in Maintenance Mode it was right in the middle and stayed there after driving it for a couple of miles and this morning (on a cold engine) it is back to just below the top mark. Picked up a tip on YouTube to use a white piece of paper to make reading the dip stick easier.
    At 1175 miles the oil was just slightly darker than the new, which would be expected.
    Other than the overly tight filter there weren't any real problems. I was surprised by how much room there is down there around the filter. A metal strap wrench like I used made for an easy job (and gave plenty of leverage for the tight filter).
    #21 Doug McC, Jun 8, 2022
    jerrymildred and Mendel Leisk like this.
  2. Mendel Leisk
    38,247
    Yeah to figure out the minimum step you need, do something like this:
    10" looks reasonable.
    I've found these points much better than the pinch welds:
    Clear of ramps too.
    Ok, just woke up: you've got a 2022. There might be similar points though. It's at the leading end of the main longitundinal floor pan rails.
    Honda's oil filter socket (aka "wrench") is a perfect fit, heavy stamped steel.
    #22 Mendel Leisk, Jun 8, 2022
    Doug McC likes this.
  3. FRCornelis
    FRCornelis Junior Member
    Los Angeles, California
    2022 Prius
    Thank you all for the comments,
    Doug McC, I appreciate your report back from the task. I was out of town for a couple of weeks and now I’m ready to tackle the job, I’m now prepared to deal with the probably over-torqued oil filter from factory, and thanks to you, I got the right tools and options in case I face the same issue as you did.
    Got the same 90915-YZZN1 oil filter, the blue washer, and 5 quarts of Toyota 0w16 oil.
    I’m not a ramp guy, nor I’m capable of doing any woodwork, so I use 2 floor jacks on each side to lift the front end with rubber pinch weld adapters to protect the paint and lift it evenly, then I use wheel cribs from Race Ramps (I love these) I have 4”, stackable to 8” cribs but just using the 4” gives me enough clearance (at least on my 3rd gen) for a simple oil change. I will do it this week at about 1,200k or less.
    The cribs will allow me to lower the car while it’s draining in case the lift angle from the cribs/ramps prevent a complete drainage, at least for my very first oil change.
    Did you prime the oil filter? I know is mounted sideways and it’s going to be messy, hopefully to mitigate the ticking noise from the valve train at first start-up? or no relevant?
    Just out of curiosity, you mentioned a 1.5” lift was necessary to fit your low-profile jack, both of my jacks are the exact same one you have Item # 64545 at Harbor Freight which is about 3.5” inch at the saddle point. So, I’m guessing you used the front center jacking point of the vehicle (which is now moved way down there on the 4gen) so you can fit the Pittsburgh without hitting anything, then you fit the jack stands under the front pinch welds. Correct?
    I’m debating if your method is better than mine, but since I’m using wheel cribs, I do have the freedom to use the pinch welds jacking points without the aid of any pre-lift. I don’t know why Toyota moved the center jacking point that far.
    Oh well…
    Thank you &
    hope everything is good!
    Best regards,
    -FC
  4. Mendel Leisk
    38,247
    Don’t prime oil filter.
  5. FRCornelis
    2022 Prius
    Is that the way you personally do it or is it a reason against it? I only ask for learning purposes.
    -FC
  6. Mendel Leisk
    38,247
    I’ve just never bothered. Too, with horizontal filter it would be a gong show??
    jerrymildred likes this.
  7. FRCornelis
    2022 Prius
    Right, sideways it's going to be a mess, it's not even stated on the service manual either.
    Can't be done on gen3 either do to the paper media filter oil filter type.
    -FC
  8. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Well, ... if you tip the filter fast enough and get the threads started fast enough, and spin it fast enough ... It's theoretically possible, but you'd have to do all those steps in about a micro second. :LOL:
    Or ... use very high viscosity oil -- something about like axle grease would stay in there. :whistle:
    #28 jerrymildred, Jun 27, 2022
  9. Doug McC
    955
    351
    Midwest
    2022 Prius
    I didn’t prime the filter, mainly since it is so small and I figured I would end up loosing most of it once I got the filter installed.
    Yes your guess is correct on the lift point and jack stands.
    With the cribs I would think your method would be a lot less hassle (less going back and forth to get the single jack lined up on the lift point).
  10. Mendel Leisk
    38,247
    Low rise DIY ramps may allow enough clearance to use the front/centre jacking point with a typical floor jack. Say two layers of 2x? There’s two clearance issues: getting the jack under there, and then having enough headroom to work the jack handle.
    our sons Mazda CX-5 is sim.
    jerrymildred and Doug McC like this.
  11. thomassster
    thomassster Member
    238
    Colorado, US
    2019 Prius
    XLE AWD-e
    Since we talked about jacking up the car, some things I’ve experienced, rhino ramps seem to work out of the box for me. There is just enough clearance for my 2019 awde version. Can’t say other models are the same clearance. Other options to handle the low clearance, even with my low profile harbor freight jack can’t fit under front jack point, if you have 4 jacks stands, you can initially raise up the rear first and put it on jack stands, and it’ll give you just enough clearance for the front.
  12. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    Of course you can't easily fully pre-fill a horizontally oriented oil filter without making a mess, but you can certainly partially pre-fill it with no problems. I did that for many years, pre-Prius. Whether that ritual was worth the effort, who knows?
  13. FRCornelis
    2022 Prius
    I figure it is not. Otherwise, it would be mentioned in the ALLDATA procedure. Same scenario for all other cars I ever worked on, it was never stated in the repair procedure.
    I didn't prime mine as I wanted a very clean installation, and yes, I did hear the valves ticking upon the first start up after the oil change for maybe a second or two but it felt like an hour and 1/2 to me LoL but still, during that very first ICE start up of the day it does it anyways since day 1. I don’t hear this in my 2015 gen3, but that one takes 0w20 not w16 like the new one so who knows if that is a contributing factor.
    Funny fact, the factory oil filter, upon first inspection (before touching it) it was leaking a bit of oil from the gasket. -who's to say?
    Well, I’m glad I purchased the extended Toyota Care warranty.
    -FC
  14. dacoobob
    dacoobob Member
    83
    45
    Kansas City, MO
    Four Touring
    my 2 cents:
    I always replace the crush washer with a new one when putting the oil pan plug back in. crush washers are one-time-use items.
    I don't bother priming the oil filter, that's an old wives tale from the days when oil circulation systems were very different.
    for jacking up the Prius I don't bother with a floor jack since it's such a pain to get it under-- I just use the little scissor jack that came with the vehicle to lift one side, put in a jack stand, then do the same on the other side. using a drill to run the scissor jack, it's faster this way than messing with a floor jack.
  15. thomassster
    thomassster Member
    238
    Colorado, US
    2019 Prius
    XLE AWD-e
    Believe it or not, in my younger years of owning a 2nd gen Prius, I didn’t realized those washers stick on the oil pan that I just added another washer. I at one point had three stacked washers, I never had one drip on my garage floor and I had no issue with oil loss. I now know what I did was pure stupidity, I’m astonished thinking now how three stacked crushed washers didn’t cause a leak.
  16. thomassster
    thomassster Member
    238
    Colorado, US
    2019 Prius
    XLE AWD-e
  17. Mendel Leisk
    38,247
    With enough washers the drain bolt’s getting a significantly diminished number of engaged threads, lol.
