Oil filters no longer available
Discussion in 'Gen 2 Prius Technical Discussion' started by Fart, Aug 23, 2022.
  1. Fart
    Fart Junior Member
    For the past 2 years I had a bulk supply of oil filters [90915YZZN1] and I'm down to my last oil filter. I went online to my nearby dealers parts website and it says the oil filter is now no longer available.
    What are the options now? I've used Wix oil filters in the past but they are not as cheap compared to the Toyota ones.
    I see websites like this that seem to carry the filter yet the Toyota website says it's no longer available. Has this happened before and it later comes back in stock or is it just gone now?
  2. Mendel Leisk
    42,354
    That sounds preposterous; try phoning a dealership parts department.
    Fart likes this.
  3. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    I bought two of the same part # about three weeks ago at my local Toyota dealer.
  4. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    Literally every single department store and auto parts store near you has an oil filter that fits on your Prius and the hundreds of different labels are nearly irrelevant because there's only a few primary manufactures of oil filters and all of them do nearly the same job. I mean how loyal to a label on a box of cardboard do you think you need to be?
  5. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Your dealer filters or Toyota filters are cheaper than fram tough guard at Walmart I find that hard to imagine but no matter and wix too that's on the lower end of the scale unless they make some top of the line filter or equal to tough guard and the like for the Gen 2 this is a spin on like 4397 or 4297 I can't remember by heart but it's one of the most popular. That should not be any kind of issue you should be able to get the frams by the case online and I would think wix too is wix gone out of business or something?
  6. PriusCamper
    13,467
    5,435
    If you really want OEM Toyota oil filters, simply type into Google: Denso Oil Filter and buy 'em
  7. ChapmanF
    19,033
    From the same fine merchants who will tell you they're selling Denso spark plugs?
    Doug McC likes this.
  8. PriusCamper
    13,467
    5,435
    More research needs to be done... I simply asked Google who makes Toyota branded oil filters and that was the answer, but it's also likely the default answer for all Toyota parts that Toyota doesn't make themselves. There's plenty of parts makers beyond Denso for Toyota.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Was the N1 the one that replaced the F2?
    #9 TMR-JWAP, Aug 24, 2022
  10. ttou68
    ttou68 Active Member
    351
    211
    That's correct, N1 replaced F2.
  11. ChapmanF
    19,033
    As many eBay and Amazon buyers have learned, there's also plenty of parts makers calling their stuff Denso.
  12. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    And we all know Google is never wrong
  13. Mendel Leisk
    42,354
    Just belly up to dealership parts department, say you need oil filter (and drain bolt washer) for such-and-such car; they’ll fix you up. (y)
  14. highmilesgarage
    highmilesgarage Active Member
    494
    185
    Kansas City
    I just bought 2 this weekend, one for my camry hybrid and one for Prius. Did an oil-change-weekend. I usually buy the oil filters at our local Toyota dealer since Walmart and parts store can't beat their price and with free drain plug gasket too! I paid $13 for both.
  15. Mendel Leisk
    42,354
    I usuu it usually get stiffed a buck or two for that washer.
  16. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    I have to check but I know I paid for the washer but the filter and washer combined were right around $6 or $7, so it looks like a wash. ;)
    EDIT: $5.41 and $1.13 =$6.57. (So, does that mean I got a “free” washer) ;)
  17. Mendel Leisk
    42,354
    Yeah my latest was $7.91 for the filter (same as yours, I did the conversion to spin-on) and $1.33 for the washer. Canadian funds. Sounds sim, with the conversion.
