Oil for the gen 2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Toyota2, Oct 22, 2022.
  1. Toyota2
    Toyota2 Junior Member
    81
    16
    PA
    Just one day with my used Gen2 & I marvel at the function driving traffic light to light
    noticing the motor has been off the last 15 minutes ( as long as you drive gentle from light to light )
    These buggers deliver mpg .
    The oil question ? 2008 5w30 oil was considered the choicest types for efichency
    not to mention 5w30 was conevential , flash forward today zero weights in synthetics are the current top types for efichency A 0w20 0w30 in synthetic would be best choice for motors shutting on and off due to faster flow i'm leaning towards a 0w30 Has anyone used a 0w20 in a gen 2 with good results
  2. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    I immediately noticed a slight MPG improvement on long trips when my Gen2 switched to 0W-20... And because this is recommended oil for Gen3 Prius, it seems congruent with what their recommendations were as they changed over time.
  3. Mendel Leisk
    42,355
    Ask a service department or two? I don’t think there’s been a gen 2 oil spec revision from Toyota? You can get synth 5W30, if that’s your concern.
  4. Toyota2
    81
    16
    PA
    Synthetic will be choice zero or 5w would logically work as each go 30 weight 0w20 would offer less resistance but it's my opinion from casual reading , cars using thinner oils also have tighter tolerances . Id figure 2008 motors are built around what was the standard but id say for sure zero weight (start up ) will allow motors less oil starvation in the extreme cold . I do live up north
    30 weight not broken have to see
  5. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,520
    Durham NC
    Im using 0/30 now all time in Gen2
  6. Toyota2
    81
    16
    PA
    Sounds like safest choice
  7. Prius RT
    Prius RT Member
    131
    245k on my gen 2 Prius. Burns a bit of oil. So I top 1 quart after 1200 miles and do oil change 2700 miles (as it comes near low level). I use the Walmart quaker state synthetic blend 5w30 .
    Any recommendations for the type of oil to use so I don't have to bother for 3000 miles?
  8. PriusCamper
    13,468
    5,437
    You might want to try full synthetic and see if the oil stays cleaner longer... This is a normal amount of oil burning for 1/4 million miles and there's no need to change the oil entirely when it gets old after adding the first quart, just keep adding more. As in 3K miles is way too soon and wasteful, especially if you use a full synthetic that's good for 10K miles. Though on older engines like yours I do it at about 8K miles. And once you're burning significantly more than a quart every thousand miles you're gonna wanna do an engine swap with a lower mileage used one, which are much more affordable than you might think.
    Prius RT likes this.
  9. Prius RT
    Prius RT Member
    131
    Is adding any high mileage oil additive useful at all here ?
    STP High Mileage Oil Treatment + Stop Leak - 15 FL OZ - Walmart.com
  10. broski
    broski Junior Member
    44
    23
    MN
    M1 0w20.
  11. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Mobil-1 5w30 with Motorkote in both my Gen 2 s.
  12. Prius RT
    Prius RT Member
    131
    How many miles on your gen 2 Prius?
    How often you do oil change ?
    Do you have to top it off in between oil changes ?
  13. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    245k on the 2005, 165k on the 2004. Change oil ever 10k. No oil needed on either between oil changes.
  14. Prius RT
    Prius RT Member
    131
    That's interesting. Walmart has mobil 1 5w30 fully synthetic but they recommend oil change every 5k miles for it.
  15. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    10,000 mile oil change intervals and you require NO oil to be added between changes? And the oil level is still on the dipstick when you hit that 10k point?
    #15 TMR-JWAP, Feb 7, 2023
    Danno5060 and Prius RT like this.
  16. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Yes, believe or not no oil between oil 10k changes, both cars, maybe it's the Motorkote.
  17. Zeppo Shanski
    Zeppo Shanski Active Member
    314
    193
    Chicagoland
    I took advantage of 46* nice weather this past Sunday after reading another oil-change thread. My ’05 G2 just turned 179,000-laps. Since a coupla months after I got it and tuned it to the edge ... I’m getting 60-mpg. I do however drive like a general grandmother. It burns NO oil. I’ve never had to top it off.
    I go with the top-line oil filter from whatever store I’m shopping at; this time NAPA. And I use 1-qt each of the following products. Hey look ... It’s just me ... That’s the way I roll. I
    m funny like that.
    0da67451-c4c5-449a-9e3f-13b07d5f49ed.63f23a0df7ef4253be9c52c998a65aa3.jpeg 3cf19d0c-5c2e-4404-85a9-964260a8fea0.6e921c2a0ea6f1093aded7416be55bbe.jpeg shopping.jpeg Promax Supply dba Acktify_ACK321444xx01ef9a.jpeg
    #17 Zeppo Shanski, Feb 8, 2023
  18. Prius RT
    Prius RT Member
    131
    Mine was giving 46 mpg after I used stp high mi oil treatment....but now back to 42mpg without it...I didn't find the stp high mi oil treatment so just added the regular stp oil treatment...maybe that's why.
    I use the synthetic blend 5w30 quaker state oil
  19. Prius RT
    Prius RT Member
    131
    anyone else with high mileage gen 2 Prius - is full synthetic 5w30 the way to go ? How often is your oil change if you use full synthetic 5k? Do you top off in b/w oil changes
    Any ideas of improving mpg? 42 seems pretty low
    #19 Prius RT, Feb 9, 2023
  20. Zeppo Shanski
    314
    193
    Chicagoland
    By-the-way ... I don’t think the oil-change had all that much to do with the MPG that I get, other than maybe that I do change it regularly. The 60-mpg that I’m getting is from the “Grandmother” way that I drive. Nobody is ever gonna confuse a G2 with any kinda sports-car ... and I certainly don’t drive it like one. I’m the guy in the right lane that everyone blows around as soon as they can. I stay within 2-mph of the limit and rarely-if-ever go over 65-mph. I glide into stoplights and never blow out of them. I use cruise-control whenever I can. I bought the 0W-16 this time because ... why not? I ran a race-car for an entire season on Rislone. I love the stuff. Hy-per Lube is also a Rislone product. The reputation of Lucas products speaks for itself. I’m not at all telling anyone to use what I use. I’m just saying that I like what I use and I’ve got a really good history going with what I use.
