1. Scott McCoy
    Scott McCoy Junior Member
    Easton, KS
    I have a 2010 prius. Recently I cleaned the intake manifold and egr valve. When I changed to oil the other day I noticed oil leaking and collected below the oil filter. After changing the oil I noticed oil leaking what , from the oil filter cover. I tightened the filter cover and it slowed down the leak but was still leaking. I then removed the filter cover and reinstalled the O ring. Same results. I am wondering if it may be leak somewhere above the filter and just showing up down hill. Any help would be appreciated.
  2. padroo
    padroo Senior Member
    2,763
    2,253
    danlatu likes this.
  3. Scott McCoy
    Easton, KS
    Thank You
    padroo likes this.
  4. padroo
    2,763
    2,253
    If you try this post how it works. Good luck.
    You can get a version of this at any automotive parts store.
  5. JC91006
    16,935
    8,646
    The o ring does not sit on the lowest position on the housing, it sits 1 position higher than the very last position.
    Hope that makes sense
    Raytheeagle likes this.
  6. Scott McCoy
    Easton, KS
    Are you talking about, right below the treads?
  7. JC91006
    16,935
    8,646
    It doesn't go below the threads, goes one notch up
  8. JC91006
    16,935
    8,646
  9. Scott McCoy
    Easton, KS
    The picture did not show up
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Was it leaking oil prior to changing the oil?
    How fast was it dripping after reinstalling the oring?
    My guess is the gasket is improperly seated;).
    Keep us posted (y).
    scona and xliderider like this.
  11. JC91006
    16,935
    8,646
    Google where does an o ring go on an oil filter. Look at the images
  12. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    There’s a big groove for it too. But easily can be overridden:(.
  13. Scott McCoy
    Easton, KS
    Yes, I noticed there was a leak before I changed oil, but then it leaked more after I changed it. It is not a drip drip, but is a slow ooze. On the filter cover there is a large space after the threads. does the O ring fit right under the threads or at the bottom?
  14. Mendel Leisk
    42,293
    It fits in that space, not at the bottom. Here's a semi-explanatory picture from the Repair Manual. There's a better picture on the oil filter box, but I'd have to dig more to find:
    Also, there's some component a little further up on the back wall that can leak oil, some sort of oil pressure sensor? There's been one or two instances of leaking from that, reported here.
    danlatu, Raytheeagle and padroo like this.
  15. Scott McCoy
    Easton, KS
    Thank You All. I will check this out tomorrow.
    Raytheeagle and Mendel Leisk like this.
  16. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Here's the image Mendel referenced from the filter box. If you can look under my lableing that this is for my 2013 Prius, you can see the left side is designated "OK" the right side is designated "NG" (no good)
  17. Scott McCoy
    Easton, KS
    Well, I went out this morning and changed the O ring to the correct position, but I still had a slow leak. It is very humbling to find out that after 9 years of doing something, you find out you have been doing it wrong. Like they say "live and learn". But it is not true that "you can't teach an old dog new tricks".
    If any have any ideas where the leak could be coming from and what I have to take off to find it.
    Thanks
    Scitt
  18. Mendel Leisk
    42,293
    So oil filter O-ring was in wrong position?
    Here's info on the Oil Pressure Sensor. They suggest to remove front/right wheel, access through wheel well.
    #18 Mendel Leisk, Feb 2, 2018
  19. Scott McCoy
    Easton, KS
    Yes, the O ring was in the wrong place. I will check the Oil Pressure Sensor in the morning. Thanks
  20. Scott McCoy
    Easton, KS
    OK, I checked the oil sensor and what I saw was the actual sensor looked fairly clean, but where the wire plugged into it was covered with oil and dirt. The oil went up the wire and down an adjacent wire. Just my thoughts would be that if it were the oil sensor would it not be leaking from around the threads and would not run up a wire. I'm thinking something above is leaking and the oil is running down the cable. I looked around the area and could not find the culprit. Any thoughts?
