Oil level 3/8" above top dimple on dipstick
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cycledrum, Feb 27, 2010.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Not mine. p.464
    'Oil capacity drain and refill - with filter : 3.9 qt ( 3.7L, 3.3 imp.qt.)'
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Also, p. 366
    warning notice
    * when replacing engine oil
    > Avoid overfilling, or the engine could be damaged
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    There must be an error in the 3.9 qt. spec. in the owner's manual, when doing filter change also.
    That is the source of the problems. I don't have access to Toyota Tech Info Serv. to see what the service spec is.
    I like the idea of leaving a post it note on the steering wheel ... one that is taped down and has BIG letters. :)
  4. Patrick Wong
    18,210
    6,510
    The Toyota repair manual also indicates 3.9 US qts.
    Either the spec is wrong or the dipstick is wrong.
  5. bisco
    51,957
    honestly, if little things like this are going to put you off from buying a toyota, then you will probably never buy one. all cars/dealers/mfgs have small issues and these are great places to discuss and learn from. but nothing is ever going to be perfec. it really is a small issue in the scheme of things.
  6. bisco
    51,957
    patrick, do you have any feel for fuel savings with lower oil levels?
    thanks! paul.
  7. richard schumacher
    7,664
    1,046
    United States
    I suspect the manual is in error because it involves two translations: one from engineer to technical writer, and again from Japanese to English. It seems to me more likely that the dipstick correctly reflects the designers' intent, since it should have gone directly from their CAD tools to the factory.
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    We have beaten this around in other threads; IMO it is better to trust the dipstick than trust the manual - the consequences are benign by having the level slightly lower than maximum, but the consequences of overfill can be hazardous to the engine.
    2 people like this.
  9. Patrick Wong
    18,210
    6,510
    Hi Paul,
    My 2004 with 99K miles is consuming a moderate amount of engine oil, around 0.75 quart in 7,500 miles. This started after I tried using 0W-20 synthetic oil a couple of years ago. I've since reverted to 5W-30 synthetic.
    Hence I've had some personal experience with varying amounts of engine oil in the crankcase. However the car also has other changes going on, like new tires, new iridium spark plugs, seasonal weather changes, changes in seasonal fuel formulation, etc.
    My guess is that you might notice ~2 mpg improvement at a lower engine oil level, i.e., 2.75 US quarts instead of 3.5 US quarts.
    Should you decide to try a similar experiment I encourage you to make sure the engine oil level never drops below the bottom dipstick dimple, to avoid engine damage.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Little things add up. Like I said, I'm not a DIY'er, I don't want to change my oil and I wouldn't trust a quick change place. I'd like to think my Toyota service department could routinely change my oil without overfilling.
    I'm not trashing Toyota, but this isn't the first thread dealing with the fact that Toyota service departments nationwide seem to have an issue with filling the oil to the proper level for The Prius. It's not my feedback, it's many owners that are doing everything from leaving notes, bringing in their own oil supply, and/or siphoning oil from the system at home using tubing...
    IMO it should be done, and is simple enough for Toyota to simply get the message out to dealers and techs...exactly what the capacity is, and how to fill it.
    Yeh, it's a small issue, but if I owned a Kia Rio, I'd want the oil filled properly. The tolerance in the gap that caused the potential sticking in the accelerator pedals seems to be pretty small too, it's attention to detail from manufacturing to service that builds a great car company....imo this is something Toyota can easily address and should address.
    I wouldn't say this if this was the first thread along these lines I had seen, but it isn't.
  11. bisco
    51,957
    no argument with wanting things to be done correctly. i just feel that there is a disconnect between the mfg's and the dealers. in my 40 years and 10 or more different make and model experience, most dealers are not interested enough in getting it right, just making money. just my personal experiences. as cars get more sophisticated, this will lead to more maintenance issues at the dealer. if they put the wrong fluid in your transaxle and it quits on you, you're going to have to prove it's their fault. time consuming and costly. if you don't understand anything, how can you be comfortible driving away after service?
  12. bisco
    51,957
    thanks patrick, i'll give it a test. my 08 isn't burning any oil between 5000 mi. changes. what do you think of the irridium plugs?
    paul.
  13. Patrick Wong
    18,210
    6,510
    Hi Paul,
    I replaced the iridium spark plugs at 99K miles, with the same Denso plug model. The old plugs were in good condition but the spark gap was definitely larger than 1.0 mm which is the minimum spec. I don't have a 1.1 mm feeler gauge so I don't know if the gap exceeded the maximum spec.
    I set the new plugs to 1.0 mm, which required narrowing the gap from the factory-set spacing.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I talked to a Toyota service advisor by phone, told him the oil is about 1/4" above top dimple, checked exactly by the book, his statement ....
    ' 1/4" above the top dimple is ok. That's far less than a cup of oil. 1 to 2 quarts excess oil would be a problem, but not 1/4" over the line"
    I asked a service advisor at Toyota Sunnyvale yesterday - oil is 1/4" above top dimple, is that ok or bad?
    "Don't worry about such a small amount of extra oil, it's not going to hurt anything. If you had an extra quart of so, it could foam up in the crankcase or cause damage to the seals, but not that small extra amount"
    ... Not the exact words, but very close.
  15. richard schumacher
    7,664
    1,046
    United States
    ...or just use three quarts :_>
  16. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    Ditto
    I took in 3.5 quarts and it was still very slightly above the full mark. Take in 3.3 quarts to be safe.
  17. ETP
    2,802
    1,170
    Auburdale FL
    BTW, my MPG always goes down after an oil change and goes up over time as the oil wears out. Several cars are this way.
    I always use Mobil One!
  18. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    +1, with filter.
  19. tanteb & rgrpick
    tanteb & rgrpick New Member
    95
    My concerns also. Our local SE region Toyota dealership, JAY TOYOTA, has, over the 4 yrs we've owned our PRIUS, failed to maintain any level of quality control over its workers. After 3 yrs of regularly being charged for 5 Qts & having to have excess removed after (except some of the times I made an issue including copying pages from the PRIUS manual and GIVING THOSE SPECIFICS to the person who checked my car in); having tires deflated to an ALL AROUND 32 PSIs, receiving quite a few comped changes...but lip from the service manager the LAST TIME... we quit & go to a private mechanic!
    But, their total in-attention to Prius specs has not stopped! Two friends have new Prii from JAY...a leased model '09, and a purchased '10, and although they did not believe me at first, when they checked their receipts, and dip sticks lol, they too were being overcharged and overfilled...word spread, a coworker of the 10 owner...also with a new '10...same thing.
    Unfortunately, my private mechanic, tops in town, cannot do recalls and I just received my notice today.
    Frankly... I'm more frightened of the workers at JAY then I am of the pedal assembly, and I resent TOYOTA SE regional and/or USA for not having paid attention to complaints made in the past...you're contributing to the demise of an excellent car rep by not tightening the reigns on inept service departments.
  20. sakai
    sakai New Member
    39
    Charleston, SC
    OK, my 05 Prius is headed in for it's first dealer service visit tomorrow, so this thread is illuminating/concerning. In reading this all, I really have just this question - most oils used in cars today are synth blends (if not outright full synthetics). Why aren't the lube guys doing the work right and not overfilling? If I'm the service manager, this is a simple economic problem - if I can use 1/2 less quart on every oil change, over time this would save the dealership a bunch of money.
    I can tell you what I'll be checking tomorrow night after the car sits a bit. :eek:
