Oil Maintenance Required Display?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Malosos, May 19, 2017.
  1. Malosos
    Malosos Member
    112
    33
    Los Angeles
    After 1,300 miles into my oil change I'm getting the "oil maintenance required" display on my dash, checked the oil and didn't seem low, anything else I should check or is there something that needs to be reset after each oil change?
  2. DavidA
    2,342
    1,818
    Chicago western burbs
    It comes on every 5,000 miles, no matter when it was done. Search the forum for the method to kill the nag screen. If you use synthetic oil, the oil change interval is 10,000 miles.
  3. Malosos
    Malosos Member
    112
    33
    Los Angeles
    The problem is it didn't come on after the 5,000 miles, came on after 1,300 miles and I am using synthetic, do you mean nav screen?
  4. NavyLCDR
    NavyLCDR Active Member
    201
    125
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Was it reset properly when the oil was last changed? You have to manually reset it, there is no automatic reset just because the oil was changed.
  5. Malosos
    Malosos Member
    112
    33
    Los Angeles
    It was changed about a month ago and by the looks of it wasn't reset properly, didn't know it had to be reset, never did that in my 05 Prius...how does one manually reset it?
  6. Mendel Leisk
    40,583
    The Owner's Manual description of this light says:
    Engine oil replacement reminder light*1
    (for vehicles sold in U.S.A.)
    *1: For details, see “Service reminder indicators and warning
    buzzers— —Instrument cluster” on page 117.
    But the light itself shows:
    In other words, it's saying "some" maintenance is required. Maybe go with that? Or better yet, since it is just a dumb miles counter:
    Follow the Warranty and Maintenance Booklet. All the intervals are miles or months, whichever comes first. If you adhere to both parameters, you're going to diverge from the miles counter sooner or later. And so many things come up, you do maintenance when it's opportune.
    Ultimately, it's up to you what you do and when. Just get adept at turning the light off, and do what you want for maintenance?
    Malosos and bisco like this.
  7. DavidA
    2,342
    1,818
    Malosos likes this.
  8. Mendel Leisk
    40,583
    In Canada we don't have the reminder.
  9. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    The OP shows a 2005 Prius in his Signature, but apparently now/also has a Gen 3. When you say
    Actually, the requirement is not for synthetic oil, but rather for 0W-20 oil (which in reality will be synthetic) in order to go 10,000 miles. If you don't use 0W-20, you should change at 5,000 miles in the Gen 3. For example, it's possible to buy synthetic 5W-20 oil, but then you should change after 5,000 miles, according to Toyota...
  10. Malosos
    Malosos Member
    112
    33
    Los Angeles
  11. Malosos
    Malosos Member
    112
    33
    Los Angeles
    I sold my 2005 a month ago & purchased the 2010 right after, will update my profile eventually...I am using 0W-20 oil but curious if the oil change should come sooner since the Prius has 170k miles.
  12. bisco
    51,154
    might be a good idea. keep an eye on the stipdick, 2010's can be burners.
    Malosos likes this.
  13. Malosos
    Malosos Member
    112
    33
    Los Angeles
    Thanks for the heads up, I will.
