Oil over filled can affect anything?
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, Jul 17, 2019.
  1. Mendel Leisk
    42,354
    Oil change with/without oil filter change is 4.4/4.1 US quart, so yeah, taking the oil filter housing should extract 0.3 US quart. Judging from the dipstick that would get it pretty close to the top mark.
  2. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    What you meant, if I pull the Filter Housing completely off, It wouldn't drain all the oil from oil sump?
  3. Mendel Leisk
    42,354
    I've never done that, but I've read that here many times, I believe that's the case. Basically that the sump level is somewhat lower.
    You could hedge your bets: unscrew the housing most of the way but not completely, and just cock it a bit. I believe you'll see a bit over a cup come out, then it'll subside.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    AND it probably says that on the OTHER side of the stick.
    Regardless I think he is wasting his time and is worrying unnecessarily.
  5. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    After I posted, I figured out that the pointy end of the dipstick is up and the handle is down, and that’s the full marker showing; so it’s slightly overfilled. That was not clear in the early photos.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    As I was running my errands this morning, my oil change required message popped up. 5k and no oil usage. YaY just what I wanted to do when it’s 95 degrees and 75% humidity.
  7. bisco
    52,862
    it comes up every 5k, but you only have to change it at 10.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I know. But I want at least one more oil analysis before I start going longer on the changes.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I’m at 13,000 miles and yet to change engine oil.
  10. bisco
    52,862
    going for the 100k record?:cool:
    Bay Stater and Raytheeagle like this.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    95% hwy miles, redline + Mobil 1 synth 20K oil filter. Check level and color every other day
    #31 Grit, Jul 21, 2019
  12. bisco
    52,862
    I've changed mine 7 times in 20,000 miles :oops:
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    You either do plenty of hauling or auto cross on the daily to & from work!
  14. bisco
    52,862
    na, i just change it yearly, no matter the mileage. i know its probably not necessary, but i don't have the guts to do otherwise. its about all i spend on the car.
    Bay Stater, RMB, Raytheeagle and 2 others like this.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    A fella in here posted last week that he’s only changed crankcase oil 3 times in 100,000 miles driven.
    Bay Stater likes this.
  16. bisco
    52,862
    that was my reference. hey, he made 300k, must be doing something right
    Bay Stater and Grit like this.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Good thing yours not an oil burner, neither is mine. We must be doing something right also.
    Bay Stater and bisco like this.
  18. bisco
    52,862
    i just wish i knew what...
  19. Tekken
    Tekken Member
    260
    77
    Ok.. After slowly untight the Filter Housing and let it drain aprrox 0.3 - 0.4 quart out. I also level it car and recheck. Prefecto
    Bay Stater, RMB, jb in NE and 2 others like this.
  20. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    Looks low
    J/k. Good job. Now go have fun driving it carefree!
    -Spiral
