Oil over filled can affect anything?
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, Jul 17, 2019.
  1. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Yes, about 90% of the way from low mark to full mark in my experience.
    4.2 litre rounds to 4.4 quarts, not 4.5. I'm careful not to overfill.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    On a new car on which I have not yet changed oil, I look in the manual for the volume then I short fill by about 1/2 quart. After that settles out, I see where it is on the stick and make the adjustment. Then I note the final amount, write that down and put that amount in each time.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Would these be the same car makers that bother to print "Do Not Overfill" in the owners manual?
    Am I suppose to gamble on at which point overfilled goes from being harmless to harmful?
    That's why I think if you embrace an approach to the matter, I think it's better to simply say...do not overfill as opposed to saying...a few ounces overfilled won't hurt anything.
    Bay Stater, Tande and jb in NE like this.
  4. Mendel Leisk
    42,354
    Ah yes, and Toyota concurs.
    Bay Stater and CR94 like this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Whatever works for YOU.
    The manufacturer is covering his own tail, mostly for legal warranty disputes.
    What he is saying is the right thing to accomplish their objectives.
  6. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    All right guys.. I drain my overfilled oil and luckily nothing happen on this overfilled.
    I was on Toyota Dealer this morning for an Inverter Software Upgrade Recall and I asked them what's my warranty on HV battery and need to inspect? (The Answer is : NO Engine Light up, No need to check.) They offer me for Brake Pad replace for $55 and License plate light burn out replace for $45.
  7. Mendel Leisk
    42,354
    Oh my lord don't go for that. Up here the bulbs are around $2 (CDN), and the swap is:
    1. open hatch.
    2. pop out the access hatch panel (there's one on each side, for left/right bulbs)
    3. twist bulb connector counterclockwise, remove old bulb
    4. insert new bulb into connector (try to keep your fingers off it, or wipe it clean with isopropanol)
    5. insert connector and twist clockwise
    6. reinstall access hatch panel
    #67 Mendel Leisk, Jul 25, 2019
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I would tell them yes replace pads on all 4 wheels and no charge for labor $55 + tax out the door. And for plate lights, I would tell them, no getting a ticket for dead plate lights is cheaper than paying $45 for bulb replacement. They would then stop going over the list of recommended services.
  9. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I bought the assemblies in the attached picture 18 months ago off Wish.com. I have to say that they still work as they did on day 1 and they were worth every penny in my opinion. They are probably overkill when it comes to illumination on the plate but the illumination also helps with rear vision on the back up camera as well, due to the angle the leds are aimed at.
    Robert Holt likes this.
  10. Mendel Leisk
    42,354
    Missed attachment? My favourite stunt btw.
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I hit the wrong button. LoL. Typing with left thumb and right index finger on the lifeinvader device isn’t as easy as it seems.
  12. Tekken
    Tekken Member
    260
    77
    Front Pads only $55... Rear Pad has 70%.. Front Pad only 30% left.
  13. Tekken
    Tekken Member
    260
    77
    Should I take try of coolant on my Gen 3 Prius? I was on toyota dealership, 1Gal 50/50 for $29. Only 10.99 at local walmart.
    douglasjre likes this.
  14. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Is that the same stuff that was labelled "Asian Formula" not long ago? If so, it is OK.
  15. Tekken
    Tekken Member
    260
    77
    Hello everyone...
    Cleaning my ERG pipe and Throttle body today.. I see more than 1 table spoon of oil under the throttle body and ERG pipe has built up some junk in.
    ER pipe built up junk carbon is normal on this 2013 model and possible on rest of ERG system.
    Throttle body has 1 table spoon oil.
    Only has 94000 miles on this 2013 prius.. got 51 miles per gallon with gamma drive.
    I hope it not oil overfill on last time cause oil over filled.
  16. bisco
    52,862
    sounds about right
  17. Tekken
    Tekken Member
    260
    77
    Since I went on that far, I want to take off the manifold and clean it. Should I change the PCV valve too? Don't want to do it again later on.
    What's the PCV valve do?
  18. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    With the intake manifold off is the best time to do the PCV valve;).
    Best access you could want for the job:).
    PCV recycles the crank case gases back to the front (think of it as a relief valve if the pressure gets high). I changed the one in our old 2010 around 120 k miles even though it still rattled when shaken:cool:.
    It’s cheap insurance (y).
    Bay Stater and bisco like this.
  19. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Controls flow of vapors and gases (mixture of blowby fumes, air, oil mist, and volatile components of oil) from upper part of crankcase to intake manifold.
  20. bisco
    52,862
    is it a pcv, pc valve, pollution control valve, or pcv valve?
    Bay Stater, Raytheeagle and RMB like this.
