Oil over filled can affect anything?
Discussion in 'Gen 3 Prius Main Forum' started by Tekken, Jul 17, 2019.
  1. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    Wow.. PCV doesn't have on local autozone.. need to order to deliver Monday.. Change PCV on 120,000 miles.. ( 25,000 miles away).
    I guess Manifold and EGR valve need to change every 250,000 miles anway.
    The EGR cooler will be f@ck hard to take off.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Positive Crankcase Ventilation Valve;).
    Or PCV Valve for short(y).
  3. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    It is the last choice, pcv valve, positive crankcase ventilation valve.
  4. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Yes! The PCV valve is an important component of the Positive Crankcase Ventilation system, ever since circa 1963.
    Bay Stater, Raytheeagle and RMB like this.
  5. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Ouch! You beat me to it!:sick:
  6. bisco
    52,862
    ray wins, but thank you all!(y)
    Bay Stater, RMB and Raytheeagle like this.
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    That reminded me of my poker playing days:).
    I used to play poker and when I’d increase the bet, I’d say “raise”. Most of my friends said “you haven’t won the game yet”:p.
    I guess “Ray’s” can mean multiple things if not written out(y).
  8. Mendel Leisk
    42,354
    Are we positive...
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Better not be negative :eek:.
    If so, that means it ain’t workin;).
    At least there is something positive in the world(y).
    Bay Stater, RMB and Mendel Leisk like this.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Not on a Prius, but I had a friend with an E150 that had a Bank 1 lean code. Took the PCV valve out and the spring was gone, but the plunger was still in it. It was the strangest thing I had seen in a long time.
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Where’d the spring go:whistle:?
    Probably not a place you wanted it to be:eek:.
    But replacement was a good idea(y).
  12. Tekken
    Tekken Member
    260
    77
    Alright... get it done.. Manifold, Throttle, EGR pipe, MAF sensor cleaned. Run smoothly..
    Tomorrow, Engine and Inverter coolant replace and Spark Plus replace. What's cap on Spark Plus you guys recommend? I'm going to use
    SC20HR-11 Denso IRIDIUM Spark Plug
    What else you guys recommend to change or replace? EGR coolant f@ck harder to take off.
    RMB likes this.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The van has like almost 300k on it. The spring can be wherever it wants to be. LoL Funny thing about it, the 5.4 in it ran so quiet at idle after I put the new PCV valve in it, you couldn’t even hear it running. The owner tried starting it and zinged the starter against the flywheel. LoL
  14. Mendel Leisk
    42,354
    I think Toyota's switched to Denso SC16HR-11, slightly hotter.
    Yeah you need to get on that EGR valve/cooler clean out.
    Bay Stater likes this.
  15. Tekken
    Tekken Member
    260
    77
    94k miles Spark Plus.. It still work, looks like not anti-seize on spark plus from manufacturer.
