Oil overfilled by the dealer
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by web1b, Nov 4, 2010.
  1. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    You guys need to think when you drive your car back to the dealers some of the oil will be still draining back down into thte pan, and if they check it after it was just running it will not be as high as it would if you wait an hour.
  2. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    Good thinking Ace. Here's what the owner's manual says:
    With the engine at operating temperature and turned off...
    wait more than 5 minutes for the oil to drain back into the bottom of the engine.
  3. web1b
    web1b Active Member
    817
    52
    So, the tech should have known that when he measured the level after I drove up and said he didn't think it was really all that much over the max line.
  4. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    How nice, This guy must have the Magic Touch?
    PS. I will have to try that trick next time I am in the garage. :)
  5. Former Member 68813
    3,524
    983
    US
    This is a very common problem. I had oil overfilled in my RAV4 every time it was serviced in 2 different dealerships. At the same time no problems with Corolla serviced by the same dealership. Go figure?
  6. web1b
    web1b Active Member
    817
    52
    Next time, I will specify only add 4 quarts and give me the bottle for the 5th quart so I can use part of it to top up the oil if it is needed during the 10K interval to the next change.
  7. Mr.Vanvandenburg
    1,359
    642
    2020 Prius Prime
    That is a new one. Good to learn new things from the experts. I doubt if the techs use the stick at all. Drain old oil, put new oil in, move on to the next car asap.
