1. jfountain2
    jfountain2 Junior Member
    40
    Pima, Arizona
    Got a 2010 Toyota Prius with 148k mileage. They say i should resell it and I will be good for another 140k it costs 140
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Did you mean reseal it? Does that mean putting on a new pan gasket? For $140 go for it if the car has no other major problems. How much farther the car will last is anybody's guess, another 140k is a good guess, maybe.
  3. jfountain2
    40
    Pima, Arizona
  4. jfountain2
    40
    Pima, Arizona
    There is no other problems
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Who are "they"? What is "it"? What costs 140? …and 140 what? …and what has the Oil pan leak got to do with it??
    (…am I really the only reader confused by this seemingly random jumble of words/ideas?) :confused: o_O :unsure:
    jfountain2 likes this.
  6. jfountain2
    40
    Pima, Arizona
    I am at a Toyota dealership . They reccomend to re seal the oil pan gasket. There is a leak. It cost 140
  7. jfountain2
    40
    Pima, Arizona
    The thread title is oil pan leak
  8. Munpot42
    1,391
    544
    What does the dealer mean by "reseal", if it's just tightening down the pan bolts, you can do that yourself.
  9. WilDavis
    2,493
    2,155
    49
    OK, I think I understand (just a bit better). The oil-pan on my previous Toyota (Corolla DX Wagon, 1993, nearly 300k miles on odometer) leaked slightly, just enough to make a ¼-sized spot on the ground if parked overnight. The dealer wanted $1300 to fix it! :eek: (something about there not being a separate gasket, but they use a sealing compound which requires the whole pan to be removed, cleaned etc. etc.) …but I held off on the repair, and waited, and waited, and eventually the leak went away (honestly! - the leak just stopped!!!) …it reminds me of the old saying "Old War-birds (aeroplanes) don't have oil-leaks, they're just marking their territory!!" :rolleyes:
  10. Mendel Leisk
    42,355
    $140's not bad. OTOH, I'd have a look at that leak, if it's just at one or two bolts and really minor leakage, meh.
  11. trungdok
    trungdok Junior Member
    45
    Boston, MA
    Where's the leakage? Is it around the edge of the pan or the drain bolt? If it's around the edge of the pan, for $140, go for it.
  12. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    Autozone...$10.99.
