Oil Pan replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Feb 10, 2020.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Yap, I totally agree. It can be even worse if he has no garage to work on his car like me.
    The oversized bolt may work fine. The fact it is not leaking oil now is a good sign that there are enough threads left. Being a 10 years old car, that may last the remaining years of operation.
    In my case on my son's Honda, since the pan was made of much thicker cast aluminum, a longer bolt of the same diameter and pitch worked fine. Still, it is missing the first half of the thread on the drain hole now. I am thinking next time I do the oil change on his car, I will install a drain valve like Fumoto with a longer threaded insert and use permanent thread locker to tighten into the pan. That way I will not have to remove the drain plug every oil change to weaken remaining threads on the pan.
    #101 Salamander_King, Feb 16, 2020
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    I never liked those so called self-threading oversized drain plugs with the pseudo-taping slots cut into the tips of the end. They never cut the deep full threads that a good tap that cuts fully formed threads.
    Again, a tap will make threads that are as good and as permanent as the original.
    ASRDogman likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Either pay to have the oil pan replaced.
    Purchase a pan and replace it himself.
    Purchase a tap of the correct size and carefully tap out the hole and hope you can catch the first
    thread correctly and clean them up. Then get a longer drain bolt and do not over tighten it.
    In MY opinion, and it is ONLY my OPINION, that those are the best options.
    But remember, "Results may vary".
    Mendel Leisk and Georgina Rudkus like this.
  4. Mendel Leisk
    42,346
    Considering what's at stake, for peace of mind, and also cus I relish a project, if it was me I'd replace the pan.
    Our son's near-new CX-5 is exhibiting oil leak at one of the oil pan perimeter bolts, we've got to get the dealership on that while it's still under warranty.
    #104 Mendel Leisk, Feb 17, 2020
    Raytheeagle and ASRDogman like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    It only took 104 posts to get to the same conclusion I gave @Taxi/Limo a couple of weeks back;).
    Glad to see your support(y).
    Salamander_King and Mendel Leisk like this.
  6. Mendel Leisk
    42,346
    I can't even remember what I had for breakfast....
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I remember what I told him at our meet up;).
    But I just polished off 80 cL of Estella while in Barcelona, so other details are a bit sketchy:oops:.
  8. Salamander_King
    11,024
    8,978
    New England
    Can we try another 104 posts, so we can make a full circle again? :ROFLMAO::ROFLMAO::ROFLMAO:
    Mendel Leisk and Raytheeagle like this.
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Why not:p.
    I've got all night:).
    Heading to some other major tourist attractions tomorrow, but here are some shots from today;):
    E0E3A20C-4EC7-4D1C-844D-F961938F3F92.jpeg DC753CFB-AFFA-4808-A9FC-3B062850419E.jpeg DD13629D-D9D3-406B-95DA-89CFC38F3C00.jpeg 6268D800-197F-4BAF-8E8F-2B942C478161.jpeg D91CE6B0-F6A8-4536-92B1-030BDE03E2D6.jpeg 5B9C2A32-9764-406F-A235-DB9DE5CC82CD.jpeg EB97477F-E8B4-4725-B5C0-01B83175A43F.jpeg AAA61F8A-8F1E-4EBD-A4BA-BDA9781BC40B.jpeg 53A165A9-CE06-4DD4-8789-955D6158644E.jpeg
    RMB, Mendel Leisk and Salamander_King like this.
  10. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Much more happened
    Replacing the oil pan may very well be the end result of this thread but I learned a great deal about different ways to approach this problem thanks to everybody giving feedback
    It's like being in mechanic school and I very much appreciate all the guys here giving me their feedback and you Ray for helping me with my car,
  11. Taxi/Limo
    526
    107
    Hello All
    I went to the parts store and the guy there sold me a piggy back for cheap to replace my oil plug
    Have any of you tried this ?
    Thanks
  12. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    Okay, I'll bite. "What's a piggy back?"
  13. Salamander_King
    11,024
    8,978
    New England
    It may work. Should be better than a simple oversized plug you have to remove at each oil change. This article may help.
    A Backup Plan For Drain Plugs | 2015-07-01 | NOLN
  14. wr69
    wr69 Member
    143
    79
    portland, or
    Don't tap and replace with a larger bolt. I just went through this mini-annoyance myself. See my thread here:
    Another Dealer Service nightmare - stripped oil pan threads | PriusChat
    Get a new pan and drain plug. It's not hard to put on, but a bit awkward without a lift. I let the dealer do mine since they are the ones who stripped the pan/bolt. Also, 27 lbft is probably too excessive for these pans plug. and given a 10+ year duty cycle. 20-24lbft is probably more reasonable, but I'm going to wait until the next Oil change to firm up a torque which I feel comfortable with. so, YMMV on the number.
    #114 wr69, Mar 4, 2022
    Salamander_King likes this.
  15. Salamander_King
    11,024
    8,978
    New England
    LOL, Yeah this was an old thread on the same topic as your incident. We don't know what the OP ended up doing on his oil pan. I hope his car is still running. :ROFLMAO::ROFLMAO::ROFLMAO:
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Most oil pan plug bolts are offered in an oversize with a matching tap to correct damaged threads. Does Toyota or a third party not offer this for this thread size?
  17. Georgina Rudkus
    3,576
    2,603
    Taylors, SC
    This is the one that you'd be referencing.
    Best Q M13 x 1.25MM Oil Drain Plug Tap Thread Repair Kit Oil Pan Screws Rethread Tool
  18. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I had this problem on my BMW. On a Prius, it’s easy to remove the oil pan, but it’s extremely difficult and complex on the BMW. I purchased a special tool from Lisle which is designed to tap a larger thread which is perfectly squared and true to the face of the oil pan. Costs about $100.
  19. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    That'll do. :)
  20. Rebound
    3,996
    2,645
    Portland, OR
    I wouldn’t use that, because it’s not the threads that keep the oil in, it’s the interface between the bolt head and the oil pan. That tool will not guarantee the hole is perfectly squared with the face of the oil pan.
    This is the tool you should use. It’s much more expensive, but you can sell it for close to what you paid for it after you’re done.
    Lisle 58850 Oil Pan Plug Rethread Kit
