Oil Pan replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Feb 10, 2020.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
    Only problem with the Lisle kit, it makes 5/8 inch threads hat are equivalent to 15mm. There is not enough "meat" on the thin walls of the stripped out threaded hole to take that large a thread.
    Carefully used, the 13mmx1.25 tap will follow the grooves in the original M12x1.25 threads and cut only a half a millimeter off the wall of the hole,
    #121 Georgina Rudkus, Mar 7, 2022
  2. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I see. Odd that Toyota doesn’t sell the small piece with the collar. That would be a simple repair.
  3. Mendel Leisk
    42,347
    And the item would be in demand, considering the gorillas dealerships employ to do oil changes.
  4. Georgina Rudkus
    3,576
    2,603
    Taylors, SC
    If it was my car, I keep one of these Dorman rubber plugs in reserve in my car, so that I can or the shop changing the oil can fill the crankcase with oil and allow the car to be driven.
    Dorman 65200 Oil Drain Plug Universal 1/2 In., Head Size N/A
    At my convenience, before the next oil change, I'd purchase this oil pan and gasket off of Amazon.
    A-Premium Engine Oil Pan Replacement for Scion xD 2008-2014 Toyota Corolla 2009-2019 Matrix 2009-2014 Prius 2010-2019 Prius V 1.8L
    FEL-PRO OS 30829 Oil Pan Gasket Set
    Instead of the silicone used to "glue" the pan to the upper pan, I either have a local non-dealer shop install the new pan or do it myself in an hour or two. Waiting hours for the silicone to cure is ridiculous.
