oil pressure reading
Discussion in 'Gen 3 Prius Technical Discussion' started by ED9593, Jan 25, 2012.
  1. ED9593
    ED9593 Junior Member
    Enfield CT
    Can I read oil pressure on my scan gauge II ? If so, how do I do it?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    There is no oil pressure sensor on the Prius, therefore there is no way to know the pressure.
    Ken@Japan
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The Repair Manual only shows an oil pressure switch and not a sensor.
  5. MrBillTulsa
    MrBillTulsa Member
    174
    35
    In the hills west of Tulsa
    Use a "T", add a sender and a guage?
    :eek:
  6. El Dobro
    El Dobro A Member
    7,106
    3,282
    Yep.
  7. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    Even better, use a "T" FORGET the sender and run a nylon line to
    a mechanical gauge. They're usually much more accurate and instant in responding to oil pressure.
  8. MrBillTulsa
    MrBillTulsa Member
    174
    35
    Maybe more instant in responding to changes, and maybe slightly more accurate, but not much in either case; and only then when properly installed and bled (purged of air).
    My biggest concern with wet guages is the possibility of leak fail, due to added lines, fittings, vibrations, etc. Think airplane - oil loss puts you on the ground, period.
    :eek:
  9. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I added a "T", a sender and an oil gauge to my 1966 mustang a few years back. It warned me of a drop in oil pressure in time to save the engine. The only drawback was that the oil leak was at the "T".
    JeffD
    Silver Pine Mica and seilerts like this.
  10. LTZR1
    LTZR1 Member
    134
    31
    Midwest
    We've installed mechanical gauges on various vehicles for over twenty years and have never experienced a failure or problem of any kind.
    Properly installed high quality gauges and accompanying fittings pose absoutely no problems whatsover. They are MUCH more accurate that most electrical gauges in our experience.
  11. Old Bald Guy
    Old Bald Guy Old Bald Guy
    89
    Ft. Worth, TX
    Here's a thought. What good is an oil gauge going to do on an engine that doesn't run continuously? Driving here in the Dallas metro, my motor starts and stops FREQUENTLY. I suspect you would probably get dizzy watching the gauge go up and down.
    Why in the heck, with modern oil and motor technology, would anyone want an oil pressure gauge on a Prius?
    I was a licensed mechanic 40 years ago when oil pressure gauges were important ... and engines didn't shut off every time you took your foot off the gas pedal.
  12. tumbleweed
    4,067
    692
    Eastern Oregon
    I think I would be more interested in knowing oil temperature than oil pressure. I would like to know how it tracks coolant temperature and if 0W20 oil really runs cooler than thicker oils.
    But it would just be to satisfy my curiosity I don't expect any lubrication related problems.
  13. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I think you just explained exactly why Toyota did not provide the oil pressure signal nor the tachometer signal. Can you imagine all of the questions and complaints they would have received when the tachometer varied all over the place at constant speed and both the tachometer and the oil pressure went to zero every time the ICE stopped ? :confused:
    douglasjre likes this.
  14. tumbleweed
    4,067
    692
    Eastern Oregon
    Actually there is a tachometer signal available in addition to the one on the ODB, here is a thread http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/73707-tach-signal.html
  15. jdcollins5
    5,131
    1,346
    Wilmington, NC
