Oil pressure when using 0W-40
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, Jul 10, 2022.
  1. douglasjre
    douglasjre Senior Member
    2,236
    745
    Null, NL
    In this test the car had been driven previously but sat for an hour and a half with the giant industrial fan in front of me while I put a fender liner in. Then I tested the oil pressure. I did an oil change with 0W-40 oil within the past day. The engine and oil temperature are around 140° for this test and I have somebody pushing the gas pedal to the floor so there's moderate RPMs. Low pressure ranges from 40 to 55 PSI. I suppose I could use 0W-30 as well but I'm concerned that 0W-20 would not give enough oil pressure in a hot climate. Does anybody hear have any testings so that we could see actual data?
  2. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    I would post your question to BITOG (Bob is the oil guy). You’ll have a lot better in depth conversations with those guys about oil vs here. Going to bitog made me feel more comfortable using 0w20 in a hot climate. I am switching over to the Mobil 1 extended performance 0w20 (take advantage of the current rebate) for my next oil change. Right now I have Toyota 0w20. Im at 156k with absolutely no signs of oil consumption other than what I find in my catch can. Btw I live in South Mississippi with some of the highest humidity levels in the country. And heat index of over 115 in the summer.
  3. douglasjre
    2,236
    745
    Null, NL
    The guy is philosophical and that's a nice discussion but what I'm searching for here is real world results with the pressure gauge and 0W-20 oil in a 3rd gen Prius. My results shown on my gauge demonstrate that 0W-40 is not causing excessive pressure
    mjoo likes this.
