Oil recomendations newbie
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by iron-icman, Jun 25, 2017.
  1. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    Look in the user manual. I believe in the UK 0W-20 may be specified due to the UK's lower temperatures and the fact its drivers are better about changing their oil than the average American. As far as everyone knows, the engine is identical for all 2nd gen Prii in the world.
    Use whatever oil is in the manual unless you haul heavy items or tow with the car. In the US 5W-30 is spec'd, so many of us (myself included) use a synthetic 0W-30 for a little extra efficiency when cold.
  2. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    The UK Prius Gen II manual specifies 5W-30. 0W-20 was officially sanctioned for the Gen II (and I think any UK Toyota hybrid) in retrospect sometime after 2010 when the Gen III was released. 0W-20 was specified for the Gen III.
    So, either is ok and it is temperature that mainly affect the differences region to region.
    iron-icman likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Never seen a 0-30 weight oil in my very long life.
    0-20 is a very thin oil. The engine valve train sounds very loud on that weight. I only use 5-30
    Mobil 1 or mostly Redline 5-30 which is very high performce oil with added zddp package that becomes more like a 40 weight oil at temperature. I like it as I spend a lot of time at 75-80 miles an hour when I drive my Prius.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    If it was me?
    And we are talking about a "new" used car, where the oil is low?
    I'd just bypass the whole "top it off" or "add engine oil routine".
    Oil Changes are relatively cheap,- just go get it fully changed.
    You can establish communication with your chosen dealer, they can give you a recommendation as to oil weight to use, ( I'd probably go with 0W-20 ) and with a full Oil Change and Filter, something I think you should do anyway, you aren't worrying about "mixed" weights or overfilling.
    If you can't afford the "full check" you are planning in a few months? Just tell them you just want the Oil Change and if they do a good job you'll be back.
    But since I'd recommend anyone buying a new "used" vehicle do a full Oil and Filter change....just go get it done.
    PS.
    I think most new vehicles go with the lighter synthetic. It's what I put in my New Gen 3 Prius, 0W-20 is what is recommended in my New Honda Fit.
    But if the service department recommends the heavier Oil? I'd just go with their recommendation.
    iron-icman and Kevin_Denver like this.
  5. Currahee
    Currahee Member
    103
    34
    CT
    edthefox5 likes this.
  6. Kevin_Denver
    581
    425
    Denver, CO
    Thanks, is it Europe where 0W-20 is spec'd in the user manual? I thought there was at least a country or two where this is true, remembering from another thread, but I may just have a memory gap.
    That's the exact oil I use and the place I buy it at, as it's a great deal! Depending on when I have my oil changed I may switch to 0W-20 for wintertime.
  7. Former Member 68813
    3,524
    983
    US
    nonsense, too basic to waste time on explanations.
  8. Former Member 68813
    3,524
    983
    US
    there is an image of a poster from toyota canada wildly circulated on the web and accepted as dogma. supposedly it shows 0W20 for majority of toyota cars (old and new). i suspect it was fake or misprint.
  9. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That has been pointed out already.
    No need to rub it in.
    But you DID take the time to post an insult non-the-less.
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I need to get out more. I never even heard of 0-30 before synthetic or otherwise.
  11. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Thank you all for your help much appreciated off to Scotland this weekend to visit family so this has helped it's about a 3 hour drive looking forward to it the first proper outing in the car
    Raytheeagle likes this.
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Its probably an oil eater so the next day after a long drive before you start the car check the oil. Do this every few days till you get a handle on if its losing oil or not. Run the oil real low and you'll be buying a new engine.
  13. Former Member 68813
    3,524
    983
    US
    sorry man, when i posted, i didn't see the second page where people gave you grief about it. I overreacted.
