Oil Selection For Warm Countries
Discussion in 'Prius c Technical Discussion' started by Mushtaq Ahmed Lakhani, Apr 17, 2018.
  1. Mushtaq Ahmed Lakhani
    Karachi, Pakistan
    2014 Aqua
    Hi Members,
    I am facing problem in selecting the right Oil for my Japanese Toyota Aqua 2014. The recommended oil on Manual is 0W-16, Which is not available in Pakistan, while for Prius C 2014 is 0W-20, but here the weather is very hot and sometimes reaches 50 degree C. I tried to google for the temperature range but did not found any till yet, any help in here.
    Regards.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    IIRC, 0w-20 is better for warmer climates than the 0w-16. I want to say that I recall 5w being suggested for super hot climates.
  3. shazoo49
    shazoo49 Junior Member
    Lahore,Pakistan
    5w-30 is a good option too as this grade is recommended in Pakistani premium car dealership like Audi BMW MB
    #3 shazoo49, Apr 17, 2018
    Mendel Leisk and ztanos like this.
  4. Mushtaq Ahmed Lakhani
    Karachi, Pakistan
    2014 Aqua
    5W-30 is not recommended for Hybrid cars. Think 0W-20 will be the best option.
  5. shazoo49
    Lahore,Pakistan
    You can say 5w-30 not recommended for your hybrid Prius c.please consult your local dealer prior to change.Bare in mind these Toyota models are not made for Pakistani market so more homework to do for choosing correct oil
    XT1585 ?
  6. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I have always advocated that we should stick to manufacturer recommendation so 0w-20 is the way to go.
    I would worry about the quality, as each oil manufacturer has its own formulation.
  7. Mendel Leisk
    42,345
    5W30 was the specified oil for 2nd generation Prius (up to and including 2009 model year) in North America. There a few 3rd generation (2010~2015) N.A. owners here also using 5W30 (instead of spec'd 0W20), especially higher mileage cars with some oil consumption.
    I really don't think you can go wrong using 5W30, especially considering your climate. OW20 also is ok, it is spec'd for third gen, even in Australia. But perhaps 5W30 is safer for engines, in extreme climate.
    ozmatt, SFO and Raytheeagle like this.
  8. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I agree with you as I had done some checking for hot climates and in Australia i found this;
    Raytheeagle and Mendel Leisk like this.
  9. hassan310
    hassan310 Junior Member
    29
    PK
    Toyota dealership recommend me this oil. The results are promising.
    #9 hassan310, Apr 18, 2018
  10. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Does it mention GF-5 on the back?
  11. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    They also have this one also. Choice is yours
  12. Mushtaq Ahmed Lakhani
    Karachi, Pakistan
    2014 Aqua
    I contacted Toyota Indus and they said they do not manufacture nor import Aqua so they can not help me out in any regard for Toyota Aqua.
  13. shazoo49
    Lahore,Pakistan
    This is what I mean in my last post Indus motor,honda atlas or Suzuki Pakistan when you visit them sometimes they even don't entertain you saying we did not sell this car so we can not take this car moreover they have their own local car which usually visit 50 to 60 car in single day neither technician take pain nor they have training when they visit Indus motor Karachi I have many friends in Honda and Toyota dealership so this is my personal experience all Prius Aqua vezel fit insight owner usually looking a local workshop rather than to go to dealership
    XT1585 ?
  14. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I have seen 0w-20 at Toyota dealership in Lahore.
    You worry too much, just enjoy your car.
    The climate is much harsher in Lahore, I am using 0w-20 (KIXX) without any problem. I use original Toyota oil filter and change it with every oil change at 5000kms intervals.
  15. Eric34
    Eric34 New Member
    Sacramento
    Isn’t choosing the right oil viscosity for cars about climate conditions? For example where I live temperatures go as low as -14c and up to 44c in the summer. Recommended operating temperature for 0w20 oil is -34c to 30c. So, In order to protect the engine at 44 Celsius degrees climate conditions, I need to use greater than 40w oil. I want to say then maybe I should use 0w-50 oil which would cover it for all climate conditions. Or should I use 0w20 for winter, and 10-50 for the summer?
  16. Elektroingenieur
    2,515
    3,288
    Three Touring
    Climate is only one consideration; fuel economy is another. In the U.S., for the 2014 Prius model in your profile, the Owner’s Manual (PDF) recommends SAE 0W-20 engine oil for all conditions.
    The page shown in your photo appears to be from an Owner’s Manual issued in Australia, where SAE 0W-20 oil might not have been universally available at the time of publication.
  17. Talha Maqsood
    Talha Maqsood Member
    46
    26
    Pakistan
    2015 Aqua
    "0" refers to temperature which helps start the car in cold weather conditions, it does no harm to the engine if used in warm weather, like Pakistan, number "20" Refers to viscosity of Oil at 100°C. as temperature increases viscosity increase. Low viscosity oils are being recommended in almost all modern engines to achieve higher fuel economy, Aqua is Hybrid car designed for Fuel efficiency, That is why 0W20 is being recommended. one more thing is that AQUA being hybrid car requires more frequent engine start than a normal car, its a requirement of engine that engine oil should reach quickly to its desired location that is why low viscosity oils are being recommended for Hybrid cars.
    P.S. I am using LIQUI MOLY 0W20 best oil available in Pakistan, run 10K KM easily
  18. Mendel Leisk
    42,345
    I’d put my money on a regular oil that meets the specs, and stick with a short oil change interval, say 6 months or 5k miles.
  19. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    Er, what leads you to think that the Liqui-Moly 0W-20 isn't "a regular oil that meets the specs"?
    AFAIK that stuff is very well made. It's the same weight indicated by the manual, and with an ILSAC GF-6A rating it meets Toyota's GF-5 spec.
    And apparently available in Pakistan. I'd use that in a heartbeat.
    Talha Maqsood and Mendel Leisk like this.
  20. Mendel Leisk
    42,345
    Ok. It was just when I hear a name like that, and mention of extended oil change interval, my (admittedly knee-jerk) reaction is it's overpriced snake oil. :oops:
    Talha Maqsood likes this.
