Oil soaked wheel well liner
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amarino, Jul 14, 2022.
  1. amarino
    amarino Active Member
    144
    105
    99
    I noticed the passenger side wheel well liner was soaked in oil last night when doing my oil change. Looking around the wheel well and engine bay but there are no leaks and nothing else is dirty, not even the back side of the wheel well liner. Only the bottom side the faces the road. Tire / wheel / all suspension / strut / CV boots / axle / etc are all dry. I took down the liner and the inner fender behind it is also dry.
    I think its been like this for a while because I can see it streaking down and back along the body skirt (or whatever that is called)
    Driver side for reference, all clean.
    52,789
    maybe the tire kicked someting up off of the road, but didn't retain it due to spinning?
  3. amarino
    144
    105
    99
    It's looks too "neat" for having ran over something. You would think it would have splashed around more in there but from the pics everything else is dry.
    It looks like something would have been slowly dripping from the top and soaking in, but there is no way for oil to leak in there and again everything else is dry, even the topside of the wheel well liner. Just the bottom / road facing side is wet
    52,789
    is it wet to the touch?
  5. amarino
    144
    105
    99
    Yeah it is wet and oily to the touch, but like it's soaked in and not fresh / dripping wet. Here is a video I took that shows behind the liner and its all dry as well.
