Oil splash on rear left side of engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MeGuinness, Mar 30, 2017.
  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Just changed engine oil and filter....and i noticed that the left side of the engine is all splashed with oil. Anyone with same problem? Is that a pressure switch? Thanks Thanks 1490865614486.jpg
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    add some uv dye to see where its coming from
    m.wynn likes this.
    52,863
    are the fill cap and dipstick tight?
  4. MeGuinness
    MeGuinness Member
    217
    78
    UK
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    What's the mileage on the odometer? Engine warranty is 60mo./60k miles which covers seals and gaskets.
    Semi common problem on the Gen 3 engine is a timing cover gasket oil leak.
    #5 xliderider, Mar 31, 2017
  6. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Mileage is 198k miles .....,i will have to look at my friend newer 3 gen Prius to see if it as same problem!
  7. Mendel Leisk
    42,355
    I looked at our 2010 with 66,000 km: it's all dry/clean there.
    Can't recall if I've mentioned before, but pcv valve clogging may cause crankcase pressure and maybe start pushing oil past seals? Maybe you've looked at that already though?
  8. Currahee
    Currahee Member
    103
    34
    CT
    We have the same issue on our 2010 since before I started working on the car a couple years ago. I just leave it alone. It's either imperceptibly slow or old seepage that has stopped long ago. The engine burns about 1qt per 2500 miles and doesn't leak any oil on the floor or splash shield.
  9. bisco
    52,863
    does the 2010 have the timing chain gasket?
  10. xliderider
    8,140
    3,280
    Honolulu, HI
    Yes
  11. bisco
    52,863
    isn't that a problematic area?
  12. Currahee
    Currahee Member
    103
    34
    CT
    The timing chain cover isn't something you can take off without removing the engine, I think. At least it would be very difficult.
  13. bisco
    52,863
    maybe some sealant?
  14. Currahee
    Currahee Member
    103
    34
    CT
    Actually here's a video of someone replacing the seals on a similar engine (more like the Gen 2) without removing the whole thing:
  15. xliderider
    8,140
    3,280
    Honolulu, HI
    LOL, I like how all the fasteners and bolts are all only "hand tight" and come off with ease.
  16. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    xliderider likes this.
